Set custom DNS on Plusnet 582n
macman2
Hello,
Anyone know how to set DNS on the plusnet router? I had a poke in telnet but cant find the option. Anyone know where it is or how to set them?
jojopillo
Re: Set custom DNS on Plusnet 582n
Hi macman2
:dns server route add dns=212.159.13.49 metric=1 intf=Internet
:dns server route add dns=212.159.13.50 metric=2 intf=Internet
Should do the trick.
Jojo Smiley
macman2
Im guessing if for example I wanted to use the IP 8.8.8.8 and 8.8.4.4 would I just replace the ips you listed with those?
jojopillo
Yes, correct Smiley
macman2
Works, Thanks very much.
