Set a maximum price limit for your broadband to £0 is no more... not!
- Set a maximum price limit for your broadband to £0...
12-01-2011 12:55 AM
OK they did it now!
Thanks a lot. I guess this month is my last, and right when i temporarily moved to the £11.49 deal.
How will this change affect you? Especially those that relied on this feature? Now more sadistic reasons to upgrade your value package to £11.49.
Re: Set a maximum price limit for your broadband to £0 is no more!
12-01-2011 1:13 AM
12-01-2011 1:49 AM
12-01-2011 2:14 AM
12-01-2011 7:49 AM
Phil
12-01-2011 8:35 AM
It wouldn't let you change to £0 additional as you'd already used an additional 5GB last billing month. If you change it now you should be able to set it to 0 as your usage reset overnight as today is your billing date.
12-01-2011 10:17 AM
That in turn means you run the risk of running up your bill for next month, if you forget, or if you go over the limit before you manage to log in..
Perhaps you need to be able to manage 2 values: The default value to be applied to all future months; and an overridden value for this particular month.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
19-01-2011 2:49 PM
Quote from: Chris @paqize
ah thats great news indeed!
yippee, im not moving afterall! atm im on the 60gb cause i need to do some heavy adownloading then back to valueeeeeeeeeeeeeee!
