Set A Broadband Price Limit
alanf
In the Member Centre Set A Broadband Price Limit it says "Enter the maximum amount you want to spend on extra usage and click 'Change' ".
If you enter 1, for example,  the message "Please enter an amount that is greater than your minimum limit." appears. So it is actually asking you to enter the maximum that you want to spend each month in total.
The wording should be "Enter the maximum amount you want to spend and click 'Change'" or perhaps  "Enter the maximum amount you want to spend including extra usage and click 'Change'". The present wording is incorrect.
James
Re: Set A Broadband Price Limit
Do you think that changing it to:
"Enter the maximum amount you want to spend." would be appropriate?
alanf
Yes. That's why it was one of my two suggestions.  Huh
Quote from: alanf
The wording should be "Enter the maximum amount you want to spend and click 'Change'...
James
Sorry, it's a Monday Smiley
I'll get a problem raised to content.
alanf
Thanks Jameseh.
