Service Status 82648
- Service Status 82648
28-08-2014 8:52 AM
Re: Service Status 82648
28-08-2014 9:08 AM
28-08-2014 10:04 AM
We've just updated the service status as the issues we were seeing seem to have now been resolved.
If you are still having problems, I would recommend raising a fault here so we can take a look into it for you.
Cheers,
Dan
28-08-2014 4:11 PM
30-08-2014 8:13 PM
31-08-2014 12:47 AM
no difference noted as yet. Thanks to Dan for taking notice.
Marc
02-09-2014 9:27 AM
10-09-2014 12:44 PM
Quote from: Dan Hi Dennis,
Cheers,
Dan
Openreach engineer came yesterday morning but the ticket hasn't been updated.
10-09-2014 12:46 PM
10-09-2014 12:52 PM
10-09-2014 1:27 PM
Is everything alright with the connection? It certainly looks fine. Though I've just upped the profile to match the new speeds.
Dan
10-09-2014 2:02 PM
The download speed has dropped since earlier today though:
Wed 10/09/14 12:46 11.50 Mbps 10.54 Mbps 0.75 Mbps 87.112.xxx.xxx Plusnet
Wed 10/09/14 13:59 6.10 Mbps 5.95 Mbps 0.98 Mbps 84.93.xxx.xxx Plusnet
Wed 10/09/14 15:25 5.88 Mbps 5.82 Mbps 0.96 Mbps 84.93.xxx.xxx Plusnet
11-09-2014 3:54 PM
11-09-2014 3:55 PM
Your line went a bit mental yesterday which seems to have caused the speed drops. I've reset the line again to manually increase them again. However, if this doesn't go through DLM should increase them over the next few days as the line is now stable.
Dan
P.S I've just seen the message about the drop, that's because I was testing the line.
11-09-2014 3:59 PM
If it's still playing up after a few days shall I reply to the ticket if it's still open or raise another fault?
