Seriously rubbish latency and Broadband 13/2
- Seriously rubbish latency and Broadband 13/2
13-02-2013 9:38 PM
BT test shows DL at 2.00 and upload at 0.09, pretty shockingly low results.
Speedtest .net similar: http://www.speedtest.net/result/2506930782.png
Have messed about with 2nd router, always cabled to gaming pc anyways no wireless rubbish!, Put computer into DMZ etc and results still the same.
Tracerts to BBC and wow servers giving 500ms + at every hop after our own router.
Can anyone shed any light on this issue?
Re: Seriously rubbish latency and Broadband 13/2
13-02-2013 9:47 PM
http://usertools.plus.net/@gateway/
Are you on PCL-AG07 or 08? If so, it is this: http://community.plus.net/forum/index.php/topic,111170.0.html
Disconnect and reconnect your router and it should go away. (or hang around for 10 mins or so and someone will have fixed it)
Ex-Broadband Service Manager
13-02-2013 10:05 PM
For years my ping time used to be 23 to 26ms as shown in my signature with 2ms jitter, but for weeks now the lowest I've seen was 44ms.
Why has my ping time doubled ?
13-02-2013 10:08 PM
Have restarted router several times for various durations this afternoon/this evening, results in the same latency within about 5-10 mins or reconnection, sometimes a bit better sometimes a bit worse, this time for example 400 ms instead of 600ms, but thats a mile away from my usual 30....
13-02-2013 10:12 PM
http://speedtest.btwholesale.com/
13-02-2013 10:42 PM
$ mtr bbc.co.uk
HOST: My_Computer Loss% Snt Last Avg Best Wrst StDev
1. My_ADSL_Gateway 0.0% 10 3.0 5.5 3.0 11.2 2.9
2. lo0-central10.ptn-ag02.plus. 10.0% 10 170.5 89.8 56.1 170.5 36.5
3. link3-central10.ptn-gw01.plu 10.0% 10 162.6 84.9 46.4 162.6 32.2
4. xe-1-2-0.ptw-cr01.plus.net 10.0% 10 317.2 92.7 41.0 317.2 86.2
5. ae2.ptw-cr02.plus.net 10.0% 10 438.8 115.4 44.5 438.8 123.8
6. ae2.ptw-cr01.plus.net 10.0% 10 562.6 125.8 45.8 562.6 164.7
7. kingston-gw.thdo.bbc.co.uk 10.0% 10 679.0 136.0 40.9 679.0 204.3
8. ??? 100.0 10 0.0 0.0 0.0 0.0 0.0
9. ae1.er01.rbsov.bbc.co.uk 10.0% 10 874.6 157.7 42.8 874.6 269.3
10. 132.185.255.60 10.0% 10 889.6 158.0 39.6 889.6 274.8
11. virtual-vip.thdo.bbc.co.uk 10.0% 10 798.5 146.8 42.2 798.5 244.9
13-02-2013 10:46 PM
Download speed 5.47 mbps
Up speed : 0.07
Ping : 375.50
When going to the further diagnostics received folowing:
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
Tracert to BBC site
Tracing route to www.bbc.net.uk [212.58.246.95]
over a maximum of 30 hops:
1 <1 ms <1 ms 1 ms 192.168.2.1
2 528 ms 494 ms 569 ms lo0-central10.pcl-ag01.plus.net [195.166.128.182]
3 713 ms 620 ms 674 ms link5-central10.pcl-gw01.plus.net [84.93.249.8]
4 * * * Request timed out.
5 552 ms 579 ms 777 ms ae2.pcl-cr02.plus.net [195.166.129.7]
6 467 ms 663 ms 567 ms ae2.pcl-cr01.plus.net [195.166.129.6]
7 * * * Request timed out.
8 258 ms 257 ms 208 ms kingston-gw.thdo.bbc.co.uk [212.58.239.6]
9 * * * Request timed out.
10 618 ms 679 ms 565 ms ae0.er01.cwwtf.bbc.co.uk [132.185.254.93]
11 760 ms 799 ms 605 ms 132.185.255.165
12 523 ms 473 ms 551 ms bbc-vip016.cwwtf.bbc.co.uk [212.58.246.95]
For the fun my tracert to Blackout battlegroup on World of Warcraft aswell
Tracing route to 213-155-152-66.customer.teliacarrier.com [213.155.152.66]
1 <1 ms <1 ms <1 ms 192.168.2.1
2 563 ms 817 ms 523 ms lo0-central10.pcl-ag01.plus.net [195.166.128.182]
3 700 ms 632 ms 664 ms link7-central10.pcl-gw01.plus.net [84.93.249.12]
5 596 ms 553 ms 512 ms xe-11-1-0.edge3.London2.Level3.net [212.187.201.209]
6 484 ms 463 ms 394 ms ae-0-11.edge4.London2.Level3.net [4.69.200.126]
7 687 ms 670 ms 621 ms ae-3-3.ebr1.London1.Level3.net [4.69.141.189]
8 738 ms 777 ms 588 ms ae-58-113.csw1.London1.Level3.net [4.69.153.122]
9 646 ms 654 ms 673 ms ae-1-51.edge5.London1.Level3.net [4.69.139.75]
10 542 ms 486 ms 330 ms ldn-b5-link.telia.net [213.248.96.37]
11 548 ms 551 ms 451 ms ldn-bb1-link.telia.net [80.91.248.217]
12 732 ms 997 ms 871 ms prs-bb1-link.telia.net [80.91.254.209]
13 729 ms 754 ms 505 ms prs-b7-link.telia.net [213.155.134.225]
14 * * * Request timed out.
15 * * * Request timed out.
13-02-2013 10:51 PM
13-02-2013 11:02 PM
13-02-2013 11:04 PM
13-02-2013 11:10 PM
Can you do that mtr again?
13-02-2013 11:18 PM
The latency itself has just been constant, After restarting router each time and reconnecting to WoW, it starts at 100ms but within 5 minutes is back up to 500ms+ every time, even been in the 2000+ range at points during the evening.
Have checked from several machines in the house aswell, do seem to be getting same sort of results on speedtests etc from all of them.
14-02-2013 12:03 AM
Is it possible to find out when my line went to being interleaved ?
What would trigger a line to become interleaved ?, as far as I know my line has always been noise free and at maximum bandwidth for a max DSL line, i.e. 7.150Mbps.
What do I need to do to remove interleaving and ensure that it doesn't return ?
With the recent latency problems, I have not seen ANY drop in speed, but have seen frequent but short periods where multiple web pages don't load on first attempt but always subsequently appear correctly with a browser refresh - mostly on eBay !.
In an attempt to overcome these page loading problems, I have set my DrayTek gateway to reserve 25% of upstream bandwidth for QOS, and enabled "Outbound TCP ACK Prioritization" and "UDP Bandwidth Control", with some but not complete success.
Because I have lost significant upstream speed by enabling outbound QOS, would it be at all possible to upgrade my line AT NO COST TO MYSELF to "Max Premium" to uncap my upstream speed, so that I can assist you with debugging this issue with the fastest capability achievable on my connection ?
14-02-2013 12:25 AM
$ mtr bbc.co.uk
1. My_ADSL_Gateway 0.0% 10 4.4 4.4 3.0 6.8 1.4
2. lo0-central10.ptn-ag02.plus. 0.0% 10 44.1 36.5 33.2 44.1 3.9
3. link3-central10.ptn-gw01.plu 0.0% 10 42.1 43.5 41.6 50.9 2.7
4. xe-1-2-0.ptw-cr01.plus.net 0.0% 10 42.8 43.2 42.2 45.1 0.8
5. ae2.ptw-cr02.plus.net 0.0% 10 49.0 49.1 41.9 95.9 16.6
6. ae2.ptw-cr01.plus.net 0.0% 10 42.7 50.3 41.9 91.1 15.4
7. kingston-gw.thdo.bbc.co.uk 0.0% 10 43.5 45.4 42.1 64.7 6.9
9. ae1.er01.rbsov.bbc.co.uk 0.0% 10 47.9 44.3 41.5 53.8 3.8
10. 132.185.255.60 0.0% 10 43.4 44.5 42.1 48.5 2.1
11. virtual-vip.thdo.bbc.co.uk 0.0% 10 44.3 43.1 42.3 44.3 0.7
14-02-2013 12:58 AM
$ mtr bbc.co.uk
2. lo0-central10.ptn-ag02.plus. 0.0% 10 238.8 65.8 33.8 238.8 67.6
3. link3-central10.ptn-gw01.plu 0.0% 10 194.4 76.0 42.1 218.2 68.9
4. xe-1-2-0.ptw-cr01.plus.net 0.0% 10 103.4 68.6 41.9 174.3 44.9
5. ae2.ptw-cr02.plus.net 0.0% 10 42.8 58.5 42.7 119.1 29.9
6. ae2.ptw-cr01.plus.net 0.0% 10 272.0 71.3 42.0 272.0 71.5
7. kingston-gw.thdo.bbc.co.uk 0.0% 10 137.2 93.6 42.1 246.8 81.8
9. ae1.er01.rbsov.bbc.co.uk 0.0% 10 43.7 64.8 41.7 189.5 48.5
10. 132.185.255.60 10.0% 10 245.7 72.1 42.8 245.7 67.6
11. virtual-vip.thdo.bbc.co.uk 10.0% 10 154.7 75.7 42.7 223.3 66.5
Not so great, but way better than earlier this evening.
Time for some ZZZzzzz's
