Serious connection issues
- Serious connection issues
10-03-2013 6:13 PM
It just took 6 reconnect attempts to get any kind of throughput whatsoever.....
I normally download at 7.5MB/s and upload just over 2 with ping around 21.
At around 5:45 my connection just stopped, there was zero throughput although it was still connected. Several hops yielded exactly the same, zero throughput. I rebooted the modem, and got zero throughput, then after some more disconnects and reconnects of my router I achieved the above connection.
Te initial block of red on the bqm was when i turned off 'respond to ping' earlier on, before re-enabling it.
I sincerely hope this isn't going to be happening with any regularity
Re: Serious connection issues
10-03-2013 6:19 PM
Download all over the place plus comedy latency
10-03-2013 6:22 PM
10-03-2013 6:25 PM
10-03-2013 6:42 PM
I had several of those this evening.
10-03-2013 6:42 PM
10-03-2013 6:44 PM
Quote from: Finguz When you hop, do you ever get errors from the router saying 'connection not available or 'cannot connect to concentrator' e.t.c?
The last time i disconnect and reconnect again after about 30 seconds my router said i was still disconnected even though i wasnt
10-03-2013 6:48 PM
10-03-2013 6:56 PM
10-03-2013 7:57 PM
10-03-2013 8:16 PM
10-03-2013 9:58 PM
dick:quote
11-03-2013 1:19 PM
Sorry to see that you've been having these slowdowns, I'm going to get your line looked into further with one of my faults colleagues and we'll update your fault ticket.
11-03-2013 3:09 PM
dick:quote
11-03-2013 6:45 PM
