Serious Speed Problem Tonight !!!!
englishrick
Ok, I was noticing a few odd speed problems tonight so I decided to run a few speed tests on various speed test sites including bt speed test and I now have a faster upload than my download, I was getting between 72-75mb download and 16-17mb Upload but tonight its under 15mb Down and just under 16mb Up....Brilliant !!!!
Re: Serious Speed Problem Tonight !!!!
I can see you had a few disconnections last night;
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13831224636718.png"/>
Were they caused by you? You've no capacity issue currently at your exchange.
englishrick
Yes they were Chris, I was trying different gateways...
adie:quote
We've not seen any issues that I'm aware of, are you speeds back to normal?
englishrick
They seem to be.....We'll see a bit later on. thanks
adie:quote
