Serious Problems With Upload Speed
Mustrum
Fixes: 81
Re: Serious Problems With Upload Speed
@jab1  I don't disagree, but just wanted to check if PN had done areset before the closed the fault - hey I know, but maybe they did - if not then more ammo for that call in the morning!
jellybeanz
If I'm honest, I'm not sure what I should be looking for, but this is a current screenshot of the technical log:
Thank goodness these pictures are only kb in size - otherwise I woudn't be able to upload them to show you in the first place! 🤣
Fixes: 385
Cheers, @Mustrum
Fixes: 385
@jellybeanz - have you rebooted the Hub since the claimed 'resolution'? I suspect that if you tried the Hub1 after it, and then replaced the Hub2, this should have been sufficient to do that, so a line reset is in order.
jellybeanz
Many apologies - I'm a bit stupid - here's a technical log after resetting Plusnet Hub Two 6 minutes ago:
Fixes: 385
OK @jellybeanz  - we need to get PN to do that line reset - I'll see if I can get any action for you in the morning if you get nowhere with a second attempt by phone.
jellybeanz
Hello all - back again because a month later, my upload speed is still capped, although now at a generous(!!!) 1.5mbps instead of 0.6. I'm only trying to upload photos at approx. 6mb each, not uploading gbs upon gbs of video! 😅
I have no idea why this has happened - I have been with Plusnet for years and always had at least 8mbps upload. I haven't moved house in 3 years. I'm still being charged the same amount. What has changed? 🫤
willcutforth
Fixes: 113
@jellybeanz Please can you pop me your username over via PM and I will have a look for you? Smiley
 Will Cutforth
