Sending occasional faxes - what solution do you recommend?
- Sending occasional faxes - what solution do you re...
03-10-2009 9:14 PM
I've signed up for the Plusnet fax-to-email service, but I also need to send the occasional fax.
I don't see any fax sending solution from Pusnet. Did I miss one?
I'm using a wireless laptop (Windows/XP). I would prefer not to have to plug into a phone point.
What's the best option: sign up to an email-to-fax service? or a web-to-fax service?
Can anyone recommend a (preferably free!) provider for sending one or two faxes a month.
TIA
Martin
TIA
Martin
Message 1 of 3
(979 Views)
2 REPLIES 2
Re: Sending occasional faxes - what solution do you recommend?
05-10-2009 9:12 AM
For a few pounds you can buy a fax modem card. As to free programmes - then Microsoft fax comes with Windows. I am not aware of the facility to send a fax from the plusnet portal.
Message 2 of 3
(392 Views)
05-10-2009 10:09 AM
There are a few services out there, I seem to remember Bob using one called Yacfax to test something out. From a Google search, Faxtastic and eFax come out near the top too.
Message 3 of 3
(392 Views)
