Sending emails from non-Plusnet addresses
- Sending emails from non-Plusnet addresses
- « Previous
- 1
- 2
- Next »
Re: Sending emails from non-Plusnet addresses
11-08-2008 2:08 PM
Most domains do not have spf records but below is an example for itunes. Then if the receiving server is checking the spf it does a DNS lookup to get the IP address of the servers that are allowed to deliver emails for the domain. With the example below for itunes the IP range of the servers are 17.0.0.0/8 (which give an IP range of 17.0.0.1 - 17.255.255.254). Checking the header of a received email from itunes gives Received: from badger03003.apple.com ([17.254.6.126]) by and 17.254.6.126 is in the range specified by the spf record.
For your domain you are looking for a txt string that contains =spf1.
11-08-2008 2:24 PM
11-08-2008 2:46 PM
Are the failure seen from different recipient addresses of just the one?
11-08-2008 4:01 PM
11-08-2008 4:10 PM
11-08-2008 6:07 PM
11-08-2008 6:09 PM
12-08-2008 12:02 PM
I've passed the support ticket back to Plusnet, and have received a message this morning advising me that it has been allocated a fault number and is currently under investigation. Watch this space...!
12-08-2008 12:38 PM
I have just tested this on my own personal Plusnet account, i successfully managed to send an email using an externally hosted domain email address and the Plusnet relay servers, relay.plus.net to a personal gmail account. I then decided to try using one of the email address's you specified to see if this would go through fine using the Plusnet relay servers, and this again successfully went through without any error messages.
This would therefore lead me to believe that either your local config is incorrect some how, or the recipients you are trying to send to are simply not working.
Can you please confirm that you are using relay.plus.net as the outgoing relay server, you are connected on the plusnet platform, and that you are using no form of authentication against the relay servers when trying to send an email?
If all the above works, could you please try and setup a new account in outlook using the email settings found on the website support section.
Regards,
12-08-2008 1:52 PM
Thanks for your message. I can confirm that I was using relay.plus.net as the outgoing server, that I was connected via Plusnet and I wasn't using any form of authentication last week. It was fine on Friday, I didn't change anything, and it just stopped working over night. On Sunday, when it still wasn't working, I changed the SMTP server to allow me to send mail, and have been using that ever since. I created a duplicate copy of my mail account to test with the Plusnet server again yesterday, and it was still rejecting my messages. However, I've tried it again today, and it's working again!! The settings are definitely exactly as they were at the weekend - I've checked the account in my backup from Friday afternoon.
This is obviously really bizarre. The problem can't be on my side, since I've not changed anything and it's now just working again, so either something has happened at Plusnet or my external host to make this work again. Anyway, for now at least, it's fixed!
Thanks again to everyone who has posted in this thread to help me get this resolved.
Gary
- « Previous
- 1
- 2
- Next »
