Sending and Receiving Faxes
hamilton36
I have just activated my FAX number,  but I cannot find any details on how to use that service.  I assume, therefore, that I can only receive faxes and not send them.
Is that right?
Thanks,
Alex
Loombucket
Re: Sending and Receiving Faxes
Correct.
Faxes sent to your number arrive as an email attachment.  It actually works very well.
One thing to remember though, make sure you receive at least one fax every 90 days or so, otherwise the service will be deactivated.  You can obviously reactivate it but the number won't be the same one.
LiamM
You may want to look at a service like Yac Fax if you wish to send faxes via your PC.
puddy
Quote from: LiamM
Its very expensive!!!
Puddy
Fixes: 142
60 days notice for cancellation with no possiblity of a refund is a bit steep!
Edit: Also, I can't see any reason to subscribe when Fax2Email if free and a PCI Fax/modem can be purchsed for less than a tenner.
Forum Moderator and Customer
