Sending and Receiving Faxes
- Sending and Receiving Faxes
16-08-2007 11:31 PM
I have just activated my FAX number, but I cannot find any details on how to use that service. I assume, therefore, that I can only receive faxes and not send them.
Is that right?
Thanks,
Alex
Is that right?
Thanks,
Alex
Message 1 of 5
(1,910 Views)
4 REPLIES 4
Re: Sending and Receiving Faxes
16-08-2007 11:40 PM
Correct.
Faxes sent to your number arrive as an email attachment. It actually works very well.
One thing to remember though, make sure you receive at least one fax every 90 days or so, otherwise the service will be deactivated. You can obviously reactivate it but the number won't be the same one.
Message 2 of 5
(641 Views)
17-08-2007 12:18 AM
You may want to look at a service like Yac Fax if you wish to send faxes via your PC.
Message 3 of 5
(641 Views)
18-08-2007 12:42 AM
Quote from: LiamM You may want to look at a service like Yac Fax if you wish to send faxes via your PC.
Its very expensive!!!
Puddy
Message 4 of 5
(641 Views)
18-08-2007 2:12 AM
60 days notice for cancellation with no possiblity of a refund is a bit steep!
Edit: Also, I can't see any reason to subscribe when Fax2Email if free and a PCI Fax/modem can be purchsed for less than a tenner.
Forum Moderator and Customer
Message 5 of 5
(641 Views)
