Seeking Anti-Virus Software recommendation?
- Seeking Anti-Virus Software recommendation?
30-07-2008 7:49 AM
Can anyone recommend a good value anti-virus software package?
Norton 2005 renewal is £39.99.
Norton 2008 upgrade is £39.99.
Thanks.
Re: Seeking Anti-Virus Software recommendation?
30-07-2008 7:57 AM
30-07-2008 8:07 AM
http://www.kaspersky.com/
Their website lists the current version at £29.99 for one year or £42.99 for two, but you might be able to obtain it cheaper elsewhere.
Cliff
30-07-2008 8:26 AM
@pierre pierre, how did you get it back to anythig thats useful??? I have turned off link scanner, and tried to disable auto updates, but it still auto updates, and always wants to restart the damn system. Would very much like to know how to get it back to as it should be and not as bloated or intrusive.
30-07-2008 8:32 AM
Does yours Auto Update?, didnt think it did that as that was a moan from a lot of people, also they had to extend the life of 7.5 because of all the complaints.
30-07-2008 9:21 AM
30-07-2008 10:51 AM
Regards .....
30-07-2008 11:49 AM
Norton does impact on the performance of a PC. This is a price I am willing to pay if it provides a better level of security but I don't know whether that is the case or not. I have stuck with it on the basis of "better the devil you know".
30-07-2008 12:08 PM
I have been running this for a while and found it to be excellent.
I also have used the ESET AV Nod32
I would recommend both
30-07-2008 12:24 PM
http://www.av-comparatives.org/
How much use it is for decision-making I don't know, but it does give you some pretty interesting stats on different AV solutions.
For example, Sophos has a tendancy to report a lot of false positives according to the test, but the false positives were all on applications that many businesses won't use. So its extra aggression may well make it an ideal product for businesses, but less of a good choice for the home user.
30-07-2008 12:26 PM
Also, if you've got more than 1 PC, multi-station licences are cheaper.
The licence also includes all program upgrades as well as definition files (so no need to pay extra to get a program upgrade to a new version) and comes in 1,2 or 3 year versions. There's also a 30 day trial version (free) which can be upgraded to the full version if you buy a licence.
Have a look here for AV and here for Smart Security (includes a firewall).
30-07-2008 2:25 PM
I changed from Zone alarm after years of use....Kaspersky is miles ahead.
30-07-2008 4:22 PM
Quote from: pierre_pierre
I use AVG free. Mine auto updates every morning when the scan runs. I know AVG had problems with V8 but eventually they listened and dealt with some of the more serious ones.
30-07-2008 5:32 PM
01-08-2008 4:51 PM
It does nag you each day when it does it's update but that's all. Doesn't impact on your PC performance like some packages and it's free There is also a pro version if you want extras.
