Second day of Fibre and down to 5mb from 37mb
maxm4xww
Hi all,
I'm being inpatient I know but a drop from 37mb to 5m in the first day is a bit annoying!
I'm guessing its because I moved my router earlier, there wasn't anything wrong with the connection - is there anything I can do?
Thanks, Max
Fixes: 4
Re: Second day of Fibre and down to 5mb from 37mb
Can you do a bt speed test for me?  and a traceroute to the bbc?
http://speedtest.btwholesale.com/
Kelly Dorset
Broadband Service Manager
Fixes: 127
did you just move the router or the modem as well?
Will Moderate For Thanks
maxm4xww
Quote from: Kelly
Down: 3.57
Up: 5.61
Ping: 42.00
Speedtest.net just showed 2mb down.
Tracing route to www.bbc.net.uk [212.58.246.94]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  dsldevice.lan [192.168.1.254]
  2    26 ms    10 ms    10 ms  lo0-central10.ptw-ag04.plus.net [195.166.128.194
  3    9 ms    9 ms    9 ms  link7-central10.ptw-gw01.plus.net [84.93.248.108
  4    9 ms    9 ms    9 ms  xe-10-0-0.ptw-cr01.plus.net [212.159.1.40]
  5    9 ms    9 ms    9 ms  ae2.ptw-cr02.plus.net [195.166.129.5]
  6    33 ms    9 ms    9 ms  ae2.ptw-cr01.plus.net [195.166.129.4]
  7    9 ms    9 ms    9 ms  kingston-gw.thdo.bbc.co.uk [212.58.239.6]
  8    *
maxm4xww
Just rebooted everything and it seems to have fixed itself.
Apologies!
Fixes: 127
glad it's sorted Smiley
Glad to hear.
Let us know if anything changes or you have any other questions.
If you were to come across this again, would you be able to run a few checks?
  • Firstly a speed test at http://speedtest.btwholesale.com and run further diagnostic after the test has completed
  • Check which gateway you're on at http://usertools.plus.net/@gateway/
  • Run a pingpath command, to run the pingpath command you'd need to open a command prompt and type the following, 'pathping ntp.plus.net -q 50'
If you could post the results that would be great.
Thanks,
Chris
maxm4xww
This is happening again, approx 11mb down and 6mb up.
Mine went from 65mb to 6mb the other night.
Logging into the router, clicking disconnect then reconnect 10 seconds later solved the issue for me.
maxm4xww
Quote from: picbits
You are right, odd!
When it happens, do what was suggested above before reconnecting to a different gateway (the disconnect/reconnect business).
That way Plusnet can spot any patterns with low speed gateways and hopefully fix the issue.
maxm4xww
Well this is annoying, just disconnected everything (probably a bad idea anyway) but no better..
Edzashed
Well it could be this bad have been like this seven weeks now on FTTC..
englishrick
Quote from: Edzashed
Well if its been like that for 7 weeks I think you have grounds to leave without penalty... I shall just continue all night now gateway hopping and forget anything else i have to do that needs speed, because PN Fibre is no good for that!!
