Second day of Fibre and down to 5mb from 37mb
- Second day of Fibre and down to 5mb from 37mb
13-02-2013 7:54 PM
I'm being inpatient I know but a drop from 37mb to 5m in the first day is a bit annoying!
I'm guessing its because I moved my router earlier, there wasn't anything wrong with the connection - is there anything I can do?
Thanks, Max
Re: Second day of Fibre and down to 5mb from 37mb
13-02-2013 9:19 PM
http://speedtest.btwholesale.com/
Ex-Broadband Service Manager
13-02-2013 9:22 PM
13-02-2013 9:28 PM
Quote from: Kelly Can you do a bt speed test for me? and a traceroute to the bbc?
Down: 3.57
Up: 5.61
Ping: 42.00
Speedtest.net just showed 2mb down.
Quote Tracing route to www.bbc.net.uk [212.58.246.94]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms dsldevice.lan [192.168.1.254]
2 26 ms 10 ms 10 ms lo0-central10.ptw-ag04.plus.net [195.166.128.194
3 9 ms 9 ms 9 ms link7-central10.ptw-gw01.plus.net [84.93.248.108
4 9 ms 9 ms 9 ms xe-10-0-0.ptw-cr01.plus.net [212.159.1.40]
5 9 ms 9 ms 9 ms ae2.ptw-cr02.plus.net [195.166.129.5]
6 33 ms 9 ms 9 ms ae2.ptw-cr01.plus.net [195.166.129.4]
7 9 ms 9 ms 9 ms kingston-gw.thdo.bbc.co.uk [212.58.239.6]
8 *
13-02-2013 9:38 PM
Apologies!
13-02-2013 9:39 PM
14-02-2013 11:32 AM
Let us know if anything changes or you have any other questions.
15-02-2013 2:35 PM
If you were to come across this again, would you be able to run a few checks?
- Firstly a speed test at http://speedtest.btwholesale.com and run further diagnostic after the test has completed
- Check which gateway you're on at http://usertools.plus.net/@gateway/
- Run a pingpath command, to run the pingpath command you'd need to open a command prompt and type the following, 'pathping ntp.plus.net -q 50'
If you could post the results that would be great.
Thanks,
Chris
03-03-2013 7:05 PM
03-03-2013 7:19 PM
Logging into the router, clicking disconnect then reconnect 10 seconds later solved the issue for me.
03-03-2013 7:40 PM
Quote from: picbits Mine went from 65mb to 6mb the other night.
You are right, odd!
03-03-2013 7:49 PM
That way Plusnet can spot any patterns with low speed gateways and hopefully fix the issue.
06-03-2013 6:21 PM
06-03-2013 6:37 PM
06-03-2013 6:51 PM
Quote from: Edzashed Well it could be this bad have been like this seven weeks now on FTTC..
Well if its been like that for 7 weeks I think you have grounds to leave without penalty... I shall just continue all night now gateway hopping and forget anything else i have to do that needs speed, because PN Fibre is no good for that!!
