Second Static IP address
MathewRB
Is it possible to order a second static IP address?
Mat
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Second Static IP address
Residential customers are limited to a single Static IP address.
Business Customers can request Static IP Blocks (where available).
Chris Pettitt
Cloud Environments Engineer
MathewRB
Chris is there anyway I can get this as a Residential customer.
I will try and explain the reason why.
I use a static IP address as I have a small network storage box that I can access out and about.
A friend of mine would like to join plusnet but has to wait until the fiber is connected to his building (he has his order in)
My firend also has a box for storage and would like to access this anywhere.
As they are between addresses (it get's complicated) I said I would look into getting a second static IP address so his box will be online. Once he has his own connection then there would be no need for a second IP address.
Iam just trying to help everyone out.
Help my friend get his box online
Help plusnet get a new customer
Just trying to help out!
Fixes: 165
Unfortunately not, the only thing we could do is add a 4 block but this is only available on Business accounts. It's really not something we'd be able to do, sorry.
 Chris Parr
 Plusnet Staff
MathewRB
Well I could only ask the question! Its a shame Plusnet is a little short sited but not my lose
Rippong
What services...FTP?
Why not use the same IP and route it via a different incoming port? You don't think you need an IP for every server on the internet do you?
As above - I can access different servers on my network by using port mapping i.e.
wan port 8080 > lan ip 192.168.1.1 port 80
wan port 8081 > lan ip 192.168.1.2 port 80
etc etc.
There are ways round the issue.
Fixes: 12
Quote from: MathewRB
hardly short sighted. you're trying to do something well out of the ordinary.
besides, you don't need to IP addresses to do what you want.
you don't even need 1 static IP to do it, at the very least it could be down with a normal IP alongside a service like DynDNS.
take the advice given to you already and do it the correct way.
digitalham
It's unusual to get any static IP address on a non-business connection. I've been with quite a large number of ISPs over the years and PlusNet is the first I've come across offering the service without a monthly charge.
BE used to offer a static IP but this is uncertain now it has been taken over by Sky.
I also had a static IP on Eclipse.
