Samsung UE46F800 and Technicolour TG582n Connection Issues
- Re: Samsung UE46F800 and Technicolour TG582n Conne...
29-04-2014 2:31 PM
I have the above TV connected to Plusnet via the Technicolour router, problem is it drops the connection every so often.
I have the IP/DNS settings set to 'get automatically' but have also tried this as a fixed setting. The TV's had a new motherboard and wireless controller to try and solve the issue but it keeps happening.
Every other device remains connected without issue... Should mention it's connected wirelessly.
Any help/tips/advice welcome.
Cheers
C
Re: Samsung UE46F800 and Technicolour TG582n Connection Issues
29-04-2014 4:31 PM
Welcome to the Forums!
When the TV drops connection do all other devices (laptops, pcs, smartphones, etc) connecting via wireless drop connection as well?
29-04-2014 4:51 PM
I've got a Samsung F6200 connected by ethernet -- no problems.
Also my son has a Samsung connected by ethernet via a pair of homeplugs -- again no problems.
If the tv and router are too far apart to run a cable, then a pair of homeplugs may prove more reliable than wireless.
29-04-2014 4:53 PM
I'd advise trying "home plugs" and plugging the television into the plug - I have had zero issues since doing this with my Samsung (PS60F5500). The other bonus is that streaming video via DNLA over wireless resulted in being unable to fast forward or rewind films but through the network connection and homeplug this functionality has returned.
I've probably streamed a solid 10-12 hours of video and music through the TG-582n and homeplug combination without a problem.
29-04-2014 4:53 PM
29-04-2014 5:00 PM
You spend 5 minute writing a reply, with interruption, only to find someone's beat you by 2 minutes.
29-04-2014 5:06 PM
Is your router set to a fixed (manual) WiFi channel or is it set to auto? I have experienced a Samsung printer not "following" a WiFi channel shift, with the consequence that sometimes it was on network and other times it was not. Since changing the WiFi channel to manual (fixed) I have not seen the issue again. I do wonder if Samsung have some issues with their WiFi drivers.
One good test which you could do is to ping the TV's IP address and see if you get a response.
29-04-2014 5:32 PM
The OP can update for sure
[quote=http://www.electricshop.com/televisions/samsung-ue46f8000-46-3d-smart-led-tv-freeview-hd%20freesat-free-5yr-warranty/invt/ue46f8000]
Screen
Screen size 46"
Screen technology: LED
HD standard 1080p
Motion Rate 1000 Hz
Resolution 1920 x 1080p
Audio
Audio power: 40 W (10 W x 2, Subwoofer 10 W x 2)
Mono/Stereo Sound: Stereo
Speakers - 4
Energy
Energy efficiency class: A
On-mode power consumption 77 W
Annual power consumption 112 kWh
Connectivity
HDMI x 4
Scart x 1
Component video input x 1
Composite video input x 1 (common use for component Y)
USB 2.0 x 3
Tuner
DVB-T2 Freeview HD
DVB-S2 Freesat HD
Standard: PAL
Picture enhancement: 3D HyperReal Engine
Sound enhancement: Dolby Digital Plus / Pulse, DTS Studio Sound, DTS Premium Audio 5.1
Multimedia functions
DLNA Certified
WiFi Direct
Smart
Full Catch- Up: BBC iPlayer, ITV Player, etc
App Store
Custom smart homepage
Full Web Browser
Knowhow Movies (via app store)
Social Media (Facebook, Twitter)
Skype compatible
Webcam (built-in)
3D ready
Active 3D
WiFi capable
Built- in
Other functions
Sleep timer
Parental lock
Voice interaction
Motion interaction
GENERAL
VESA mount 400 x 400
Remote control
Media remote
Additional remote control functionality: voice recognition
Accessories included: Table top stand
Internal menu languages: 26 European languages
Dimensions: Boxed: 1139 x 711 x 204 mm (H x W x D)
Unboxed (without stand): 1033 x 600 x 35 mm (H x W x D)
Unboxed (with stand): 1033 x 634 x 25 mm (H x W x D)
Weight: Boxed: 18.1 kg
Unboxed: 14 kg
29-04-2014 5:53 PM
29-04-2014 6:25 PM
Router is located too far to run an Ethernet cable unfortunately.
All other devices remain connected when the TV drops out. I'll try having a look at the router settings and see if that makes a difference.
I'm not aware of 'home-plugs' but will look into also.
Cheers
C
29-04-2014 6:33 PM
After 20+ years in IT I actually used a set a few weeks ago and have been more than impressed by them (for what they are).
A basic set will cost you around £30 for a half decent pair - get the ones with passthrough mains plugs to save tying up a socket and don't use them on surge protector extension leads.
Plug one into the mains socket your router is plugged into, plug your router into the homeplug mains. Plug an ethernet cable between the homeplug and your router.
At your television end, plug your homeplug into the mains socket, plug your television into the homeplug mains, plug an ethernet cable between the television and homeplug.
Job done (some homeplugs may require syncing to each other the first time).
My wireless at home achieves between 18 and 35Mb download speeds, the homeplugs I use (BT 500) get me the full 60+Mb/s from the router. I had a play trying to max them out the other day but this laptop only has a 100Mb network card in and I got the full 11MB/s download through the plugs to my server.
29-04-2014 8:18 PM
Works fine on his TV.
http://www.amazon.co.uk/TP-Link-TL-PA211KIT-200Mbps-Powerline-Adapter/dp/B004INVKP4/ref=sr_1_4?ie=UT...
29-04-2014 9:30 PM
I haven't tried wireless mind you, but if I were you I'd wire it up.
