Samknows Monthly Reports
Anyone know if there is any possible way of sharing these like TBB Ping Monitors? The info is really useful and far more in-depth that TBB.
My latest report (see below for May 2013) was impressive - only a small blip on 14 May.
shalom2010
Re: Samknows Monthly Reports
The only way to share them is to copy each widget (making a screen copy) or attaching the pdf which you have done. I agree they are really useful - I showed the Open Reach engineer when he was here to prove that my upload
speed has dropped.
Fixes: 4
I do like the Samknows reports, i might add it isn't perfect, but it is a constant. IE it gives great feedback on long term monitoring without the hastle of doing it yourself. Also you can save the data as a csv or raw data.
shalom2010
Agreed. This is what I showed the Open Reach guy, before my upload speed returned to normal.
