SamKnows
- SamKnows
SamKnows
03-10-2014 1:39 PM
Afternoon people.
The SamKnows exchange & broadband package checker says i can get Plusnet Fibre, but its not an option when i try to upgrade?
Is their info wrong?
username : mrmarkus1981
Message 1 of 8
(1,851 Views)
7 REPLIES 7
Re: SamKnows
03-10-2014 1:42 PM
you need to use this https://www.btwholesale.com/includes/adsl/main.html as I doubt that Samknows looks a cab space availability
Message 2 of 8
(963 Views)
Re: SamKnows
03-10-2014 1:48 PM
Many thanks
Cant take much from the results though?
Message 3 of 8
(963 Views)
Re: SamKnows
03-10-2014 1:53 PM
looks like your cabinet isn't fibre enabled (yet) or you're unlucky enough to have a direct line to the exchange..
Message 4 of 8
(963 Views)
Re: SamKnows
03-10-2014 2:34 PM
Quote from: mrmarkus1981 Many thanks
that means no FTTC at your cabinet
Message 5 of 8
(963 Views)
Re: SamKnows
03-10-2014 5:30 PM
Quote from: dvorak [...] or you're unlucky enough to have a direct line to the exchange..
It is possible that a cabinet will be installed outside the exchange, as was for me.
Message 6 of 8
(963 Views)
Re: SamKnows
03-10-2014 5:49 PM
When I put my phone number into Samknows the exchange it told me that I was connected to was different to the exchange the BTW site gave me.
I assume BTW is more accurate than Samknows in this regard?
Message 7 of 8
(963 Views)
Re: SamKnows
03-10-2014 7:18 PM
The problem is... there are some cabs (usually in more rural areas) which are attached to another larger exchange when it comes to vdsl.
In other words your phone line goes to 'X' exchange, but the FTTC cab goes back to 'Y' exchange.
Message 8 of 8
(963 Views)
