SamKnows Whitebox Placement
- Re: SamKnows Whitebox Placement
08-02-2013 9:57 AM
I'm wondering where in the network I should place the SamKnows Whitebox? (https://www.samknows.eu/index.php/en/faq)
Here's my setup...
It's my understanding the Whitebox acts as a bridge, and passively monitors WiFi traffic plus its own LAN clients to find a quiet time to operate.
Should I place it:
1) Into the router with no LAN clients of its own (let it monitor WiFi for traffic)
2) Between the router and the AirPort (all traffic from my local network would then go through its LAN)
3) Into the AirPort (let it monitor WiFi for traffic)
Here's my setup...
Mac
Printer
iPad ---- Wireless ----> Apple AirPort ---- LAN Cable ----> Belkin Modem/Router
Phone (Bridge mode) DHCP + NAT
Neighbour
Should I place it:
Message 1 of 7
(2,042 Views)
6 REPLIES 6
08-02-2013 10:26 AM
I'm going to plug mine into my router & then my WD My Book Live back up will be plugged into the white box as per the instructions. That way it is able to monitor both the wireless traffic & the ethernet traffic into my My Book. Therefore you should plug yours into your Belkin router but not between it & your AE. I think.
Message 2 of 7
(782 Views)
08-02-2013 10:29 AM
your normal router should be used for wireless, then the samknows box plugged into your normal router and then any other network goes through the samknows box.
Message 3 of 7
(782 Views)
08-02-2013 10:48 AM
Dvorak - I know that's how it should be, but the Belkin's wireless is rubbish so it's turned off. The AirPort is doing all the wireless stuff, and the Belkin doing the routing and ADSL
Message 4 of 7
(782 Views)
08-02-2013 11:31 AM
sorry re-read it, it needs to go in between the router and your aiport. is it an extreme?
Message 5 of 7
(782 Views)
08-02-2013 11:37 AM
Quote from: dvorak is it an extreme?
No, Express, but does have a client LAN port available
Message 6 of 7
(782 Views)
08-02-2013 12:06 PM
Oh I also misread your query.
Message 7 of 7
(782 Views)
