SamKnows Broadband Speed Monitoring - "My Speed Tier"
KevH
Hi
I've had a SamKnows broadband unit installed since May this year, and I've just noticed that the Downstream Throughput chart now shows "My Speed Tier".
My download speed is around about 65Mbps, but the Speed Tier is showing 80Mbps.
Any idea what the My Speed Tier is telling me? Theoretical maximum line speed perhaps?
1 REPLY
Fixes: 247
Re: SamKnows Broadband Speed Monitoring - "My Speed Tier"
yes, your speed tier is the product maximum which for fttc is 80
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
