Sagemcom Router
malcb173
Sagemcom Router
The broadband and wifi lights flash quickly with the result that broadband does not work or extremely slowly. This happens constantly, using an ethernet at the same time is fine and if I momentarily disconnect the wifi on the router it becomes stable for a shot while.
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Sagemcom Router
The lights flashing indicates something is transferring data across the network, if this is a lot of traffic (specifically upload) it can cause slowdowns.
It's worth changing the wifi password on your router and also try disconnecting each wireless devices one by one to see if that resolves the issue.
 Chris Parr
 Plusnet Staff
Cagney1994
Re: Sagemcom Router
@Chris - Re. the 2704n router, is there any reason why I can't see all active devices on Wifi? Some are not showing at all. And as mentioned in a similar thread with the same router, the device name was showing as 'Joe Bloggs iPhone' but then changed to 'Unknown'.
Is there a fix to this?
malcb173
Re: Sagemcom Router
Many thanks and found the culprit which was stuck on upload.
