Sagemcom 2704n - slow streaming & page response
- Re: Sagemcom 2704n - slow streaming & page respons...
17-07-2015 10:16 AM
We recently had our old PlusNet router replaced with a new Sagemcom 2704n. The old router was unable to establish a broadband connection - and the line line phone appears fine.
One issue we have experienced with 2704n is bad streaming performance - pauses every few seconds, & when I try and remote work, there is huge lag when I try and type and click on remote pc.
I found this useful link to expose some connection details... http://192.168.1.254/expert_user.html
Have pasted results below.
Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (1 dB): 1.9 5.2
Attenuation (1 dB): 39.5 20.0
Output Power (1 dBm): 0.0 12.6
Attainable Rate (Kbps): 11384 1156
Path 0 Path 1
Downstream Upstream Downstream Upstream
Rate (Kbps): 11107 1167 0 0
MSGc (# of bytes in overhead channel message): 59 10 0 0
B (# of bytes in Mux Data Frame): 173 26 0 0
M (# of Mux Data Frames in FEC Data Frame): 1 8 0 0
T (Mux Data Frames over sync bytes): 2 6 0 0
R (# of check bytes in FEC Data Frame): 12 4 0 0
S (ratio of FEC over PMD Data Frame length): 0.4998 5.8862 0.0 0.0
L (# of bits in PMD Data Frame): 2977 299 0 0
D (interleaver depth): 64 4 0 0
Delay (msec): 8 6 0.0 0.0
INP (DMT symbol): 1.00 0.00 0.0 0.0
Super Frames: 5708347 5243991 0 0
Super Frame Errors: 612493 122 0 0
RS Words: 742084890 2901356 0 0
RS Correctable Errors: 102052657 499 0 0
RS Uncorrectable Errors: 15648786 0 0 0
HEC Errors: 11475274 147 0 0
OCD Errors: 8 0 0 0
LCD Errors: 8 0 0 0
Total Cells: 2417800617 254822647 0 0
Data Cells: 109074734 5024585 0 0
Bit Errors: 0 14022 0 0
Total ES: 14803 86
Total SES: 10744 0
Total UAS: 10692 81
Looks like a high number of errors?
Cheers
T
Downstream Upstream
Path 0 Path 1
OCD Errors: 8 0 0 0
LCD Errors: 8 0 0 0
Total ES: 14803 86
Total SES: 10744 0
Total UAS: 10692 81
Cheers
T
Message 1 of 7
(1,702 Views)
6 REPLIES 6
Re: Sagemcom 2704n - slow streaming & page response
17-07-2015 4:00 PM
What are HEC errors? We reset the statistics - and within 5 mins the count is up to 690,000 and growing....
Message 2 of 7
(987 Views)
17-07-2015 5:18 PM
ADSL data is sent in cells, each of which has a header - the Header Error Count is the number of cells which have required header correction.
690,000 (on the downside?) is an awful lot in 5 minutes - I think you would be better waiting for a more knowledgeable member to suggest possible reasons why, but the low downside SNR won't be helping, and there could be other issues, including your home wiring.
The new Sagecom may just be better at hanging on to the connection than the old router, but any router would struggle to provide a stable broadband connection with that many errors.
Message 3 of 7
(987 Views)
18-07-2015 9:56 AM
We're seeing alot of drops from our end.
Check the link below to see what you need to do to rule out a issue on your end.
http://www.plus.net/support/broadband/bbfaults/adsl-connection-troubleshooting.shtml
Message 4 of 7
(987 Views)
18-07-2015 10:54 AM
Thanks for your graph Matthew.
Interestinginly on Saturday 11th in afternoon there was no one using the Internet when we had a burst of disconnections.
Have this morning (Sat 18th) replaced the microfilter on phone extension sharing the router so should hopefully see some better stability.
I am worried that the speed may have been restricted by BT following recent issues.
Will observe and report back soon.
T
T
Message 5 of 7
(987 Views)
18-07-2015 11:51 AM
Message 6 of 7
(987 Views)
20-07-2015 9:50 AM
Hi Matthew, the broadband appears more stable now. Suggests the old micro-filter was a problem.
Was able to stream movies etc with no significant glitches, but did see pauses on Sunday evening.
Have posted DSL stats below :-
Downstream Upstream
SNR Margin (1 dB): 3.0 6.3
Output Power (1 dBm): 0.0 12.7
Attainable Rate (Kbps): 12012 1176
Path 0 Path 1
Rate (Kbps): 11246 1169 0 0
B (# of bytes in Mux Data Frame): 175 167 0 0
M (# of Mux Data Frames in FEC Data Frame): 1 1 0 0
T (Mux Data Frames over sync bytes): 2 1 0 0
R (# of check bytes in FEC Data Frame): 12 0 0 0
S (ratio of FEC over PMD Data Frame length): 0.4993 4.5714 0.0 0.0
L (# of bits in PMD Data Frame): 3012 294 0 0
D (interleaver depth): 64 1 0 0
Delay (msec): 8 1 0.0 0.0
Super Frames: 7007761 6211727 0 0
Super Frame Errors: 290277 68 0 0
RS Words: 911008711 831910 0 0
RS Correctable Errors: 127314902 0 0 0
RS Uncorrectable Errors: 2978256 0 0 0
HEC Errors: 2033953 68 0 0
OCD Errors: 0 0 0 0
LCD Errors: 0 0 0 0
Total Cells: 3014606599 313133354 0 0
Data Cells: 275851686 13193210 0 0
Bit Errors: 0 4261 0 0
Total ES: 14315 53
Total SES: 5276 0
Total UAS: 3135 81
HEC errors still appear to be high?
Downstream Upstream
Path 0 Path 1
OCD Errors: 0 0 0 0
LCD Errors: 0 0 0 0
Total ES: 14315 53
Total SES: 5276 0
Total UAS: 3135 81
Message 7 of 7
(987 Views)
