Safeguard not working properly!
Leah66688
Ive done all my setting on my safeguard. i reset the router, i waiting till this morning to see if it works, but it doesnt. It still keeps blocking me out of pages. Nothing i do is working. What should i do?
Cagney1994
Re: Safeguard not working properly!
@Leah66688 - Have you gone back into the Safeguard settings to see what's wrong?
Leah66688
Yes I have anni can't anything wrong with the settings
Fixes: 160
Is it definitely Safeguard causing this issue? What error shows up when you cannot get to a website?
 Chris Parr
 Plusnet Staff
Leah66688
Yes because my mobile internet let's me go on them sites. Just goes to the safeguard protect page. I click to permantly unblock the page and it just goes back to that page
Leah66688
What do I do?
Fixes: 160
We're seeing 2 connections on your account, have you given a router to a friend/family member or helped them to connect with your details? If so they need to ensure they are connecting on their own username/password as this will be causing issues with Safeguard as it won't know which IP address to assign the profile to.
 Chris Parr
 Plusnet Staff
Leah66688
I got sent out another router box that I need to send back. But it hasn't been open. It's still in its packaging.
Fixes: 160
Can you send me a private message with the serial number of the router you're currently using please.
 Chris Parr
 Plusnet Staff
