[SOLVED] can't log in to view usage
i'm using the same browser i've been using for years without issue.  this morning i can't log in to view my usage.  will someone fix this for me as 'contact us' also requires a login, which i cannot do.
Fixes: 172
Re: can't log in to view usage
things seem to have had a wobble, no one can log in. usergroup disappeared for an hour amongst other things.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
yep.  wee glitch.  can log in now.
Fixes: 172
Re: [SOLVED] can't log in to view usage
yeah there were a couple of announcements, there was a data centre outage.
