SNRM going up; speed going down
- SNRM going up; speed going down
21-06-2010 8:11 PM
Noise going up an speed going down steadily over the past several weeks. Previously had the same problem a few months back, until SNRM reset by PN.
What causes this? Nothing has changed. Should be able to easily get 8M; and used to.
Message 1 of 2
(565 Views)
1 REPLY 1
Re: SNRM going up; speed going down
22-06-2010 11:05 AM
HI fp,
done a few tests here and getting good results, so you could really do with going through the troubleshooting guide
http://www.plus.net/support/broadband/bbfaults/slowspeed.shtml
and if you're still suffering then raise a fault.
Jojo
Jojo
Message 2 of 2
(251 Views)
