SNRM going a bit daft.
- SNRM going a bit daft.
13-08-2013 11:25 PM
Don't know what happened at 17:43. Presumably a drop in sync at a bad time of the day
Looks like a router reboot is needed at a better time of the day.
Quote Tue 13 Aug 2013 17:41:41 Rx-Noise=5.8 Rx-Sync=13191
Tue 13 Aug 2013 17:42:11 Rx-Noise=5.8 Rx-Sync=13191
Tue 13 Aug 2013 17:42:41 Rx-Noise=5.8 Rx-Sync=13191
Tue 13 Aug 2013 17:43:11 Rx-Noise=0.0 Rx-Sync=
Tue 13 Aug 2013 17:43:41 Rx-Noise=0.0 Rx-Sync=
Tue 13 Aug 2013 17:44:11 Rx-Noise=9.1 Rx-Sync=11347
Tue 13 Aug 2013 17:44:41 Rx-Noise=9.1 Rx-Sync=11347
Tue 13 Aug 2013 17:45:12 Rx-Noise=9.1 Rx-Sync=11347
Message 1 of 6
(1,211 Views)
5 REPLIES 5
Re: SNRM going a bit daft.
14-08-2013 12:14 AM
Or has DLM decided to raise your target noise margin to 9dB?
David
Message 2 of 6
(711 Views)
14-08-2013 10:39 PM
Looks like it as a reboot left it stuck up there.
and....
Time for a line reset request methinks.
and....
Quote Download speedachieved during the test was - 9.89 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 9.96 Mbps
Message 3 of 6
(711 Views)
14-08-2013 11:08 PM
As you have a Billion BiPac 7800N, have you tried setting the target SNR, to say 4.5dB, on the '/snr.cgi' page ?
Message 4 of 6
(711 Views)
15-08-2013 10:52 AM
Message 5 of 6
(711 Views)
15-08-2013 5:59 PM
@Adam thanks for that and yes everything is back to 'normal'.
@purleigh thanks I was aware of that page but 1) my line might not take kindly to a forced SNRM at that level and 2) I prefer the BT system to pick it's own even though it does get it wrong occasionally.
Message 6 of 6
(711 Views)
