SNRM Reset please
- SNRM Reset please
SNRM Reset please
10-06-2013 7:01 PM
Many thanks
PS almost forgot could you also attach a radius graphic for the 9th and 10th of June please.
Thanks again
Re: SNRM Reset please
11-06-2013 9:12 AM
As requested,
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13709382088576.png"/>
Yo've had quite a few drops yesterday, were they you? Just need to check before I place the SNR reset as I don't want to make things worse.
11-06-2013 9:32 AM
My connection has been a bit odd lately but there are road works and new street lighting going on nearby so I was expecting issues as I mentioned here http://community.plus.net/forum/index.php/topic,115008.0.html.
Thanks Chris
11-06-2013 10:37 AM
Is the speed throttle being applied by PN or BT? If PN can some-one please help?
11-06-2013 12:44 PM
Can you post the full line stats from the N55?
11-06-2013 1:04 PM
I've placed a SNR rest on your line. It will take up to the usual 4 hours to complete.
11-06-2013 4:37 PM
Modulation : G.Dmt
Annex Mode : Annex A/L
Line State : up
Lan Tx : 12455007
Lan Rx : 4732877
ADSL Tx : 440476
ADSL Rx : 566163
CRC Down : 0
CRC Up : 0
FEC Down : 40
FEC Up : 7
HEC Down : 0
HEC Up : 0
SNR Up : 24.0
SNR Down : 8.5
Line Attenuation Up : 4.5
Line Attenuation Down : 10.0
Data Rate Up : 448
Data Rate Down : 7616
The question I guess is whether interleaving should be switched off. If so how do I get this done?
The other question is why is my IP profile only 6.5Mbps? Can this be raised and if so what is the process?
11-06-2013 4:50 PM
We can turn interleaving off if you would like us to.
11-06-2013 5:02 PM
11-06-2013 5:04 PM
James, will you please turn interleaving off.
11-06-2013 5:20 PM
Just placed that for you, should complete tomorrow.
11-06-2013 6:16 PM
PS Sorry for hijacking your thread baldrick
11-06-2013 9:38 PM
I'll leave the PC on tonight and check RouterStats and JD in the morning to see how the night went.
Here's hoping the 6dB D/S noise Margin holds well without too many errors....currently 94 HEC and 130 Error Seconds over 3 hours.
12-06-2013 9:59 AM
Fingers crossed it stays that way.
Thanks guys.
12-06-2013 4:18 PM
Modulation : G.Dmt
Line State : up
Lan Tx : 12732015
Lan Rx : 4875245
ADSL Tx : 51608
ADSL Rx : 63391
CRC Down : 0
CRC Up : 0
FEC Down : 0
FEC Up : 0
HEC Down : 0
HEC Up : 0
SNR Up : 25.0
SNR Down : 6.5
Line Attenuation Up : 4.0
Data Rate Up : 448
Data Rate Down : 8128
The only problem now is that BT report that my IP Profile is still 6.5Mb/s. Will this rise automatically or is some further action required?
Strat - I think it is me who should apologise for high jacking your thread, so sorry!
