SNRM Jump
- SNRM Jump
SNRM Jump
06-03-2012 3:43 PM
Not that I'm complaining but at 15:01 this afternoon my SNRM jumped from 6db to 6.8db, normally it floats between 5.9db and 6.2db.
Upon noticing this I did a router reboot and my downstream jumped from a shaky 7968kbs to 8128kbs.
If Openreach have done anything....bless 'em....and all without raising a fault.
How long can it last I wonder.
Message 1 of 8
(1,397 Views)
7 REPLIES 7
Re: SNRM Jump
06-03-2012 3:52 PM
Forever hopefully!
Message 2 of 8
(513 Views)
Re: SNRM Jump
06-03-2012 3:54 PM
I was going to ask for a PN profile tweak but...
Edit: PN profile is 7.15mbs anyway.
Quote Download speed achieved during the test was - 5 Mbps
For your connection, the acceptable range of speeds is 600 Kbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 6.5 Mbps
Message 3 of 8
(513 Views)
Re: SNRM Jump
06-03-2012 4:14 PM
I can tweak that down then
Message 4 of 8
(513 Views)
Re: SNRM Jump
06-03-2012 5:48 PM
You dare
Message 5 of 8
(513 Views)
Re: SNRM Jump
07-03-2012 1:39 PM
At least I didn't have a connection drop last night but it's hanging on to maximum sync by the skin of it's teeth.
Noise Margin: 5.5 dB
Connection Rate: 8128 Kbps
Line Attenuation: 25.0 dB
Power: 19.7 dBm
Max Rate: 8224 Kbps
Power: 19.7 dBm
Max Rate: 8224 Kbps
Message 6 of 8
(513 Views)
Re: SNRM Jump
08-03-2012 9:23 AM
Might be interesting to see what effect, if any, that this natural phenomenon has on all our SNR's for the next 24 hours or so!
Message 7 of 8
(513 Views)
Re: SNRM Jump
08-03-2012 2:17 PM
Wish I hadn't mentioned it now - my connection has resynched once and also lost the PPP session once in the last hour!
Message 8 of 8
(513 Views)
