SNR upped to 9
- SNR upped to 9
SNR upped to 9
02-11-2008 2:08 PM
Just been mooching around my router settings and the target snr has risen to 9 was 6 , is this BT's system doing some silly ajustments as i wasn't realy having any problems apart from the spikey pings and lag.
Message 1 of 3
(834 Views)
2 REPLIES 2
Re: SNR upped to 9
02-11-2008 3:28 PM
most likely yes. have you had any resync's lately or high error counts.
are your pings more stable now at 9 db.
whats your router reporting the atten and sync rate ect at?
Message 2 of 3
(333 Views)
Re: SNR upped to 9
02-11-2008 10:37 PM
Connection has been up for 41 hrs now resync must have been early hours saturday morning
I have raised a ticket and and got sent this no idea what it means thou , just having to go through all the normal checks etc
Interleave CRC: 1233
Interleave FEC: 156240
Connection Speed 3776 kbps 448 kbps
Line Attenuation 52 db 31 dB
Noise Margin 8 db 19 db
Quote Upstream Link Info
Loop Loss Loop Loss Add Text SNR Margin Errored Seconds HecErrors Cell Count Speed
32 18 0 0 6639037 448
Downstream Link Info
Loop Loss Loop Loss Add Text SNR Margin ErroredSeconds HecErrors CellCount Speed
52 8 0 0 38459345 3776
DSL Max Data
BIP Interface Data
Current line rate Line rate change timestamp Maximum Stable Rate Recalcuated ProfileTimestamp Maximum Stable Rate
3000 2008-11-01T00:02:42 N 2008-10-31T23:47:33 2272
Fault Threshold Rate Interleaving Flag ServiceOption ServiceOption Status ServiceOption Update Timestamp
2272 A 1
Quote R7 DSL Modem Statistics:
[DSL Modem Stats]
US Connection Rate: 448 DS Connection Rate: 3776
DS Line Attenuation: 52 DS Margin: 8
US Line Attenuation: 31 US Margin: 19
US Payload : 155549328 DS Payload: 782735040
US Superframe Cnt : 8703330 DS Superframe Cnt: 8703330
US Transmit Power : 0 DS Transmit Power: 0
LOS errors: 0 SEF errors: 0
Errored Seconds: 0 Severely Err Secs: 0
Frame mode: 3 Max Frame mode: 0
Trained Path: 1 US Peak Cell Rate: 1056
Trained Mode: 3 Selected Mode: 1
ATUC Vendor Code: 414C4342 ATUC Revision: 1
Hybrid Selected: 3 Trellis: 1
Showtime Count: 1 DS Max Attainable Bit Rate: 3776 kbps
BitSwap: 1 US Max Attainable Bit Rate: n/a
Annex: AnxA psd_mask_qualifier: 0x0000
Power Management Status: L0 DS HLINSC: 0
US ACTPSD: -345 DS ACTPSD: -355
Total init. errors: 0 Total init. timeouts: 0
Showtime init. errors: 0 Showtime init. timeouts: 0
Last showtime init. errors: 0 Last showtime init. timeouts: 0
ATUC ghsVid: 0f 00 41 4c 43 42 00 00
T1413Vid: 00 00 T1413Rev: 00 VendorRev: 00
ATUR ghsVid: b5 00 54 53 54 43 00 00
[Upstream (TX) Interleave path]
CRC: 18 FEC: 10336 NCD: 0
LCD: 0 HEC: 136
[Downstream (RX) Interleave path]
CRC: 1233 FEC: 156480 NCD: 0
LCD: 0 HEC: 0
[Upstream (TX) Fast path]
CRC: 0 FEC: 0 NCD: 1
LCD: 0 HEC: 0
[Downstream (RX) Fast path]
CRC: 0 FEC: 0 NCD: 0
LCD: 0 HEC: 0
[ATM Stats]
[Upstream/TX]
Good Cell Cnt: 3240611
Idle Cell Cnt: 153090901
Tx Packets Dropped Count: 0
Tx Bad Packets Count: 9
[Downstream/RX)]
Good Cell Cnt: 16306980
Idle Cell Cnt: 1301335589
Bad Hec Cell Cnt: 7960
Overflow Dropped Cell Cnt: 0
Rx Packets Dropped Count: 0
Rx Bad Packets Count: 0
[SAR AAL5 Stats]
Tx PDU's: 1323115
Rx PDU's: 1410909
Tx Total Bytes: 103623226
Rx Total Bytes: 736125064
Tx Total Error Counts: 0
Rx Total Error Counts: 49
[OAM Stats]
Near End F5 Loop Back Count: 0
Near End F4 Loop Back Count: 0
Far End F5 Loop Back Count: 0
Far End F4 Loop Back Count: 0
SAR OAM Ping Response Drop Count=0
# ifconfig
br0 Link encap:Ethernet HWaddr 00:1E:2A:EF:CE:9C
inet addr:192.168.0.1 Bcast:192.168.0.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1325222 errors:0 dropped:0 overruns:0 frame:0
TX packets:1411107 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:122545273 (116.8 Mb) TX bytes:756919512 (721.8 Mb)
eth0 Link encap:Ethernet HWaddr 00:1E:2A:EF:CE:9C
RX packets:1325226 errors:0 dropped:0 overruns:0 frame:0
TX packets:1411106 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:100
RX bytes:127846417 (121.9 Mb) TX bytes:756919445 (721.8 Mb)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:5701 errors:0 dropped:0 overruns:0 frame:0
TX packets:5701 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1893469 (1.8 Mb) TX bytes:1893469 (1.8 Mb)
ppp0 Link encap:Point-Point Protocol
inet addr:80.229.147.171 P-t-P:195.166.128.27 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1
RX packets:1401683 errors:0 dropped:0 overruns:0 frame:0
TX packets:1313891 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:733229361 (699.2 Mb) TX bytes:100903203 (96.2 Mb)
wlan0 Link encap:Ethernet HWaddr 00:1E:2A:EF:CE:9C
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
Message 3 of 3
(333 Views)
