SNR up again!
- SNR up again!
Re: SNR up again!
09-03-2012 3:55 PM
Re: SNR up again!
09-03-2012 4:57 PM
Re: SNR up again!
09-03-2012 5:00 PM
Re: SNR up again!
15-03-2012 1:44 PM
At 1320, I noticed that the sync had dropped to 52xx and the SNR was up at 9.1dB.
What's happened to the hard fixed 6dB and can it be restored please?
Re: SNR up again!
15-03-2012 5:10 PM
Quote from: Kingsgate15 What's happened to the hard fixed 6dB and can it be restored please?
I don't know and I'll have to look into that. It is not an easy process. I will see tomorrow how to go about getting it back.
Jojo
Re: SNR up again!
15-03-2012 8:57 PM
I'm not aware of having done anything to cause the disconnect at about 1320, particularly as I was actually setting up my printer at the time (usb). Given my past problems with disconnects between 1230 and 1430 nearly every day, I do wonder if the DSLAM is going scatty! Keith.
Re: SNR up again!
16-03-2012 10:41 AM
I'm afraid it's not going to be easy getting this done. Looking at the graph I don't see any pattern in the connection dropping at certain times. I imagine the ones over the last few days are you trying different set ups. I'm hoping this is the case anyway.
Jojo
Re: SNR up again!
16-03-2012 12:30 PM
I also discovered later in the evening that placing an active wireless router on a high frequency next to the TV is NOT a good idea! Mine caused picture blocking on most non-BBC Freeview channels and after doing some research, sorted the problem by changing the wireless channel to a lower frequency.
Anyway, I am now back on ethernet (faster than wireless) with a different router. As I still have a good connection for a long line, I'll let things settle down again.
Many thanks, Keith.
Re: SNR up again!
16-03-2012 2:21 PM
It seems to me that someone is deliberately pulling the plug on my connection - otherwise why else would a stable 9dB SNR suddenly jump to 12dB?
As the router has not lost power, these disconnects MUST be to do with the exchange end and, reinerating that which I have already mentioned, back to random disconnects between 1230 and 1430 daily.
Something is NOT right and it certainly has nothing to do with me at my end. Perhaps further investigation is required. Thanks, Keith
Re: SNR up again!
16-03-2012 5:12 PM
I would say now is the time to raise a fault. It sounds like it needs more intrusive investigation, so that would be the best course of action.
Jojo
Re: SNR up again!
17-03-2012 3:23 PM
Re: SNR up again!
19-03-2012 12:49 PM
I'm presuming you are currently in the test socket?
Jojo
Re: SNR up again!
19-03-2012 1:33 PM
Re: SNR up again!
19-03-2012 4:36 PM
Just a bit confused, because on your ticket you say it's in the master socket. Do you mean your plugged into the faceplate or the socket behind, having removed the faceplate?
Jojo
Re: SNR up again!
19-03-2012 5:08 PM
Hope that helps. Keith
