SNR target
wysie
SNR target
Was wondering if you could lower my target SNR to 6dB, ive kept my router plugged in for about 3 weeks now only resetting from the router firmware. Been syncing at much lower speeds than my last isp and this seems to be the problem  Huh
Router Stats :
Uptime: 0 days, 4:05:06
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 6,496
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 10.0 / 19.0
SN Margin (Up/Down) [dB]: 24.0 / 14.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 11
HEC Errors (Up/Down): 0 / 9
Any advice would be appreciated Smiley
Fixes: 162
Re: SNR target
If we request an SNR reset then it'll restart the 10 day training period on your line, let me know if you still want to go ahead with this.
 Chris Parr
 Plusnet Staff
wysie
Re: SNR target
Yes that would be fine  Cheesy, im getting put on adsl max premium im guessing this wont affect it  Shocked ?
Fixes: 162
Re: SNR target
I'm not actually sure if I'll be able to request it while an order is going through, I'll give it a try though.
 Chris Parr
 Plusnet Staff
Fixes: 162
Re: SNR target
It can't be done until the order completes, whilst an order is in progress the asset (broadband on the line) isn't 'active' so we can't perform any actions on it.
 Chris Parr
 Plusnet Staff
wysie
Re: SNR target
Ok, do you have any idea when you could request it  Smiley
Fixes: 162
Re: SNR target
Tomorrow hopefully once the open order has been closed. I've made a note of your username to check again then.
 Chris Parr
 Plusnet Staff
wysie
Re: SNR target
Ok thats my on max premium now, can you or any of the other PN staff reset my SNR  Cheesy
Fixes: 162
Re: SNR target
Should be in the progress of being reset, you might see fluctuations in speed over the next 10 days whilst it goes through the training period again.
 Chris Parr
 Plusnet Staff
wysie
Re: SNR target
Ok, cheers Cool.
wysie
Re: SNR target
Was wondering if you could give my ip profile a nudge on PNs side, its still at 5500  Roll eyes
Mand
Re: SNR target
Not now it isn't. Wink
wysie
Re: SNR target
Just wondering has interleaving been turned back on or is it just because its the 10 day training period, pings are around 45ms when they were 25ms before  Lips are sealed
Mand
Re: SNR target
It's not showing as active on BT's systems, does your router give you the status?
wysie
Re: SNR target
cant find where it tells you on the thomson tg585 v7 lol  Embarrassed
