SNR stuck on 15 db
- SNR stuck on 15 db
SNR stuck on 15 db
14-09-2010 6:20 AM
After reporting (to BT) several faults, in the time since going live (voice and broadband died for up to 5 days at a time), and once again on Friday last week, Openreach /BT installed a new master socket and replaced the dropwire as the insulation had perished in several places. That was Saturday morning.
For the last 66+ hours, my sync speed has been in excess of 1750 kbps (for the last 60+ hours at 1856 kbps). Although the Openreach engineer suggested disconnecting and reconnecting my router a few times, I only did so on Saturday a couple of times, and left it alone from before midnight on Saturday. I did get a similar speed a few months ago, but it was short lived, unfortunately, and in the last 2+ months the sync speed has been a bit over 1 Mbps and data sometimes 750 kbps but more often down at 350 kbps, 250 kbps, or 135 kbps (!)
Seems there was a disconnect around 22:00 on Sunday (only spotted this from 'connection duration' info on Zyxel router) but sync speed returned to 1856 kbps.
I accept getting data throughput back up to say 1.5 Mbps may take some days, but currently seems I am getting 132 kbps (see My Broadband Speed graph) <http://www.mybroadbandspeed.co.uk/results/49354551.png> while the portal reported my throughput speed at 250 kbps (and before that at 750 kbps)
So, guys and gals at PN Towers, can someone tell me how long I need to wait before asking to get the exchange 'reset' so the SNR might start at 6 db again, and perhaps work its way up a bit, but hopefully not to the same level... (I trust this is possible as Bob Pullen did this back in May), now that the line should be a lot more stable, however much it rains from now on!
Re: SNR stuck on 15 db
14-09-2010 9:07 AM
14-09-2010 9:49 AM
I couldn't have put it better myself!
@WebDude,
I would be willing to do a reset but the line would have to be showing some stability for a time. It's looking a lot better on your connection logs at the moment so I don't think it'll be too much longer before the profile lifts and then we can see how good it stays.
Jojo
14-09-2010 9:51 AM
Would have posted on Usenet but have to move kit around (since router has had to move from ground to first floor, to follow the master socket, and I have a few PCs to lug upstairs (actually, might consider using HomePlug to link a hub downstairs with the router).
Bob created ticket 33206690 in response to my May Usenet query, but today I was thinking no point creating a new ticket if it comes back with a note to say 'Your line is still being assessed by BT DSLAM so wait another 72 hours' or whatever... so... no point making a ticket until there's someone willing to consider the "SNR reset" worth doing...
14-09-2010 9:53 AM
14-09-2010 10:01 AM
Well, look, I'd be happy to reset it for you but it wouldn't be worth creating more complications at this time. You're welcome to keep nudging me though and I'll watch how it's going.
Jojo
14-09-2010 1:07 PM
Even a boost from just over "dual-channel ISDN" type speed would be an improvement (and make it possible for me to stream music - I keep getting buffering on my [Windows Mobile] phone trying to play WMP streams from the BBC {fixed at 128 kbps, so I have no option to get something slower } )
14-09-2010 1:25 PM
the BT profile is 135, our lowest is 250 but it will pick up once the DLM assesses that the line is stable enough. It doesn't matter what we change ours to, the BT one is the most you'll get.
Jojo
14-09-2010 1:46 PM
So does that mean the 250 shown on the portal is not strictly a truthful copy of the BT setting ?
Not a big issue (hope few people ever get stuck with 135 k anyway), but confirms there's no point me looking at that for guidance, for now at least....
14-09-2010 2:45 PM
Jojo
15-09-2010 1:31 PM
I guess I won't be able to watch some TV shows I missed last week... still "patience is a virtue", I suppose !
15-09-2010 3:07 PM
You shall go to the ball!
I've just ran a line test and your profile has lifted so I've nudged it from here and you should see a big improvement now.
Jojo
15-09-2010 3:57 PM
15-09-2010 4:08 PM
The administrative reset has been done now so you shouldn't have to wait too long.
Jojo
16-09-2010 10:57 AM
I don't really trust the info from My Broadband Speed at present (see info below) compared with Speedtest.net result (I didn't run it a few times, just the once for comparison).
