SNR still high
- Re: SNR still high
- « Previous
- 1
- 2
- Next »
Re: SNR still high
21-01-2016 10:16 AM
The DLM will automatically set a 3 dB target SNRM if it determines the line performance is good enough, sometimes it only takes a few days of good performance for the DLM to make a change, although I think it would normally work its way down in steps 12, 9, 6, 3.
Re: SNR still high
21-01-2016 10:41 AM
I'll see if it can hold at 3db.....
Re: SNR still high
23-01-2016 8:24 AM
Quote Bandwidth (Up/Down) [kbps/kbps]: 888 / 8,517
Data Transferred (Sent/Received) [MB/MB]: 1.04 / 26.58
Output Power (Up/Down) [dBm]: 7.3 / 0.0
Line Attenuation (Up/Down) [dB]: 14.6 / 29.5
SN Margin (Up/Down) [dB]: 10.1 / 15.1
Something is broken surely..... Had a 12db snr for months, 2 days ago it dropped to 3db for 2 days, now it's a 15db......
Can a CSR assist me to find out why this is happening please
Re: SNR still high
23-01-2016 11:42 AM
Re: SNR still high
23-01-2016 12:45 PM
Quote xDSL linestate up (ITU-T G.992.5; downstream: 8517 kbit/s, upstream: 888 kbit/s; output Power Down: 20.6 dBm, Up: 7.3 dBm; line Attenuation Down: 29.5 dB, Up: 14.6 dB; snr Margin Down: 15.1 dB, Up: 8.9 dB)
Re: SNR still high
23-01-2016 1:56 PM
Is your router one that will work with routerstats, as previously suggested that might give us more clues as to what is going on.
Re: SNR still high
23-01-2016 6:25 PM
Re: SNR still high
24-01-2016 8:02 AM
Quote Jan 24 04:21:05 PPP link up (Internet) []
Jan 24 04:21:04 PPP CHAP Receive success (Internet)
Jan 24 04:21:02 PPP CHAP Receive challenge from rhost JUNOS (Internet)
Jan 24 04:21:02 PPP CHAP Receive challenge from rhost acc-aln1.l-how (Internet)
Jan 24 04:15:26 PPP link down (Internet)
Re: SNR still high
24-01-2016 10:26 AM
Quote from: XenoGuy What do I export via Router Stats?
Not sure what you mean Routerstats is a software tool that monitors your line. It produces stats and Graphs that
can assist in finding what is causing a problem by examining the graphs for patterns.
See here: http://www.vwlowen.co.uk/internet/files.htm#routerstats ; I have found it really useful in monitoring the SNRM.
The graphs are captured on a regular basis so you do not need to be there as long as you leave it running.
The saved graphs can then be posted on here
Re: SNR still high
25-01-2016 10:01 AM
Re: SNR still high
25-01-2016 10:30 AM
I think each graph shows about 2 hours worth so you should have 5 or 6 which if not too big can be added to a single post.
using the additional Options and Attachments section.
On th upstream SNRM graph are there any blips or is it just an almost flat line?
Re: SNR still high
25-01-2016 11:07 AM
up snr is jagged
Re: SNR still high
25-01-2016 3:14 PM
and in the second picture there was a margin drop of around 0.5dB at about 16.38 - are you aware of anything being switched on at that time.
The idea is that you leave RS running so you can see when/if the SNRM recovers that 0.5dB, then see if it happens at the same time on what days.
Up SNR jagged?? may as well post a graph.
Maybe change the axis Maximum so you get more detail - perhaps 18 for the snrm I also have the sync speed superimposed on mine.
EDIT Anotherone has given thes instructions (relate to a582N but may help with configuration.
http://community.plus.net/forum/index.php/topic,144626.msg1276142.html#msg1276142
- « Previous
- 1
- 2
- Next »
