SNR staying high after line fault fixed
- Re: SNR staying high after line fault fixed
19-05-2014 2:46 PM
I am using a Netgear DG834v4 modem/router & my exchange is 1.5 miles away. PN profile: Estimated 11Mb, Current 7Mb
Dave
Downstream:
Noise Margin: 8.9 dB
Connection Rate: 9667 Kbps
Line Attenuation: 38.5 dB
Power: 0.0 dBm
Max Rate: 12160 Kbps
19-05-2014 2:51 PM
I've just completed an SNR Reset back to 6db for you.
19-05-2014 2:52 PM
19-05-2014 2:57 PM
Dave
21-05-2014 9:46 PM
New figures:
Noise Margin: 3.6 dB
Connection Rate: 11219 Kbps
Power: 0.0 dBm
Max Rate: 12384 Kbps
Dave
21-05-2014 10:34 PM
Your line has an excellent synch rate. If your line remains stable at 3dB then you are on a winner.
You might need to drop the PPP session (use the router admin page) to pick up a revised profile.
21-05-2014 11:00 PM
Then DLM decided to set my SNR to 3 as well, which my line length cannot support so requested it reset to 6. That failed and they reset my line instead, so now stuck in the 10 days of joy on 3 SNR with errors in the thousands every hour. So far 2 days in and still on 3 SNR, that after a couple of manual reboots to force a change. So I am thinking that DLM is broken.
22-05-2014 11:25 AM
Dave
