SNR slowly drops
SNR slowly drops
Im on a Thomson V8 provided by PN as my old V7 seemed to be getting a bit tired. The new one is better but there is something very odd - over time the SNR drops slowly. When I connected over 5 days ago the SNR was about 7 (and I connected at 448 / 5,088 ). The SNR has now dropped to 3,5 and the connection is still holding (even though the FEC is now 165 / NA).
Previously my SNR dropped in the evening and then rose in the morning  as I'm on an overhead cable but this recent behaviour is very odd.
Fixes: 62
Re: SNR slowly drops
It sounds like a bit swapping problem
So how do I troubleshoot that?
Fixes: 62
I have no idea with that router - when I had that problem a reboot fixed it
matt_2k34
most routers you can turn bit-swapping off..
If the connection doesnt drop, dont worry about it?
Regards
Well I was sort of thinking that  - the speed is fine and its solid so why worry, unless it screws my profile of course
matt_2k34
Will only if it drops loads of course Smiley i wouldnt worry just yet
Regards
Fixes: 52
Are you aware you can got plots of bit loading and bit swapping activity on this router using RouterStats?
David
Yes I am aware - and here is a screenshot.
Not that it means much to me ;-)
Fixes: 62
does the bit swaps over time tell you anything
Not sure.
I only powered routerstats up this morning
Fixes: 62
Usually the bit swapping would have happened earlier in the morning - this is mine (computer on sleep overnight)
However bit swapping is clearly working.
If it continues throughout the day and doesn't settle down then you just have a line with a bit of random noise on it
Do you want to remove your IP address from the picture
Would it make sense to restart it and then leave Routerstats running?
The SNR has risen slightly this morning to 4
Speedtest shows this:
Fixes: 62
The odd thing about that test is that your IP profile should be 4000kbps
You could do a resync and see what happens.
If you want to monitor over night you would need to keep the PC running
OK I've restarted everything
Maximum Bandwidth (Up/Down) [kbps/kbps]:	908 / 5,280
Bandwidth (Up/Down) [kbps/kbps]:         448 / 5,088
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 440.00
Output Power (Up/Down) [dBm]:                 11.5 / 19.5
Line Attenuation (Up/Down) [dB]:         29.0 / 48.5
SN Margin (Up/Down) [dB]:                 22.0 / 6.5
Routerstats running and I'll leave my computer running for the next day or so
As for the speedtest result - its very odd : I usually get 3.7
