SNR rest
- Re: SNR rest
- « Previous
- 1
- 2
- Next »
Re: SNR rest
15-10-2012 1:13 PM
Can you download this and see if it works with your HomeHub http://vwlowen.co.uk/internet/files.htm#routerstatslite
Message 16 of 20
(371 Views)
Re: SNR rest
15-10-2012 1:30 PM
Router is not listed so i tried user defined but its just showing noise margin 0, connection speed 0,
Message 17 of 20
(371 Views)
Re: SNR rest
15-10-2012 7:22 PM
That is unfortunate
Can you interrogate the router log and find out if the resync is at the same time or just randomly somewhere during the night
Assuming it is random then the only solution is to raise a fault and hope that the checking system will spot something
Message 18 of 20
(371 Views)
Re: SNR rest
15-10-2012 9:46 PM
HomeHubs are notorius for being a pain to get RS/DMT to do anything. It depends on version, firmware etc whether anything can be made to work.
When you got the stats in reply #12, have a look at the full address in your browser address bar when the stats are open.
In RSLite, after selecting User Defined, copy what's in the address bar and put it in the >Setip >URL tab making sure it's prefixed by only one http://
Add the login information on the Login tab. Try that and see if it works. If not, try this in the URL box - I haven't a clue if it'll work -
http://192.168.1.254/index.cgi?active%5fpage=9162&active%5fpage%5fstr=page%5fsettings%5fa%5fadsl&req...
Message 19 of 20
(371 Views)
Re: SNR rest
24-10-2012 1:09 PM
Hi could i request an snr reset, my connection has been stable for a week now
Message 20 of 20
(371 Views)
- « Previous
- 1
- 2
- Next »
