SNR rest
pajor
SNR rest
Hi, Openreach have been working on the telegraph pole my downline comes since then my noise margin has risen. Could you please reset my SNR to 6db.  I have tried test socket will the same results. Downstream was previously 3.424 mbps or above this has put my connection from 3mb+ down to 2.5, does not sound like much but it makes a difference on a slow connection.
Connection Information
ADSL Line Status
Line state: Connected
Connection time: 0 days, 11:45:14
Downstream: 3.344 Mbps
Upstream: 448 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.1 Annex A
Latency type: Interleaved
Noise margin (Down/Up): 11.3 dB / 22.0 dB
Line attenuation (Down/Up): 41.4 dB / 26.5 dB
Output power (Down/Up): 18.5 dBm / 12.3 dBm
FEC Events (Down/Up): 30608768 / 858
CRC Events (Down/Up): 135664 / 848
HEC Events (Down/Up): 325161 / 857
Error Seconds (Local/Remote): 95504 / 5355
Fixes: 62
Re: SNR rest
Can you post the actual results from the test socket and confirm that when using the test socket that no other sockets in the house are live.
I ask this because from your reported attenuation you should be getting much higher speeds and your reported errors are far too high for the short connection time
pajor
Re: SNR rest
ADSL Line Status
Connection time: 0 days, 00:00:40
Downstream: 3.219 Mbps
Upstream: 448 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Noise margin (Down/Up): 15.4 dB / 21.0 dB
Line attenuation (Down/Up): 41.6 dB / 26.5 dB
Output power (Down/Up): 18.5 dBm / 12.2 dBm
FEC Events (Down/Up): 0 / 0
CRC Events (Down/Up): 1 / 0
HEC Events (Down/Up): 0 / 0
Error Seconds (Local/Remote): 1 / 0
pajor
Re: SNR rest
no other sockets in use, router direct into test socket
Fixes: 62
Re: SNR rest
That explains part of the problem - your default noise margin is now 15dB
Although you say that non of the other sockets are in use do you get a dial tone when you plug a phone into them via a filter
Can you leave the router in the test socket until tomorrow without disconnecting and report the stats again - I want to see what happens to the reported errors
pajor
Re: SNR rest
i have a filtered master faceplate, no other filters are used. phone extension runs from back of faceplate,
so while i have router in test socket none of the phones have a dial tone
Fixes: 62
Re: SNR rest
excellent - so now let us try to find out why you are having speed problems and errors
Fixes: 10
Re: SNR rest
Is there any noise on the line when you use the phone? (You can test using the quiet line test dial 17070 and pick option 2)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
pajor
Re: SNR rest
no noise on phone line will try 17070 tomorrow as router is still in test socket
clanla
Re: SNR rest
pajor, I am a little confused by your last comment as it seems to suggest that you cannot use the phone when the router is in the test socket.  When you use the test socket, which is behind the front plate, you must still plug in a filter and you can then plug the router and a phone into the filter.  Probably I just misunderstand what you meant.
pajor
Re: SNR rest
Quiet line test was okay slight buzz but nothing really. Had a resync last night, errors are down noise margin now 16db
ADSL Line Status
Connection time: 0 days, 14:02:27
Downstream: 2.688 Mbps
Upstream: 448 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Noise margin (Down/Up): 16.3 dB / 22.0 dB
Line attenuation (Down/Up): 41.7 dB / 27.0 dB
Output power (Down/Up): 18.6 dBm / 12.3 dBm
FEC Events (Down/Up): 165295 / 6
CRC Events (Down/Up): 296 / 4
HEC Events (Down/Up): 2152 / 4
Error Seconds (Local/Remote): 47 / 23
Fixes: 62
Re: SNR rest
You shouldn't have a slight buzz
Can you post the latest stats to see what has happened since the last lot.
Also was there anything happening when the router resynched such as the phone ringing
pajor
Re: SNR rest
Hi m8 nothing happened during sync
Connection time: 0 days, 13:05:01
Downstream: 2.75 Mbps
Upstream: 448 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Noise margin (Down/Up): 16.9 dB / 22.0 dB
FEC Events (Down/Up): 2242021 / 11
CRC Events (Down/Up): 745 / 3
HEC Events (Down/Up): 4727 / 12
Error Seconds (Local/Remote): 196 / 15
Fixes: 62
Re: SNR rest
That is twice it has resynched at about the same time so something is screwing up your connection.
Which router do you have
pajor
Re: SNR rest
Router is Bt hub 3
Just done another quiet line test and there was static, not enough to really notice when talking on the phone
