SNR reset request
- Re: SNR reset request
- « Previous
- 1
- 2
- Next »
25-03-2015 1:52 PM
Very few lines, even the best, will perform at their theoretical level. For setting reasonable expectations in people's minds, using the reported attenuation (in speed calculators) produces a figure which might be reasonably attained without entering into the debate about how much different ADSL(1) and ADSL2+ will report the attenuation to be on the same line. Is it 1.5dB, 2.5dB, 3dB or some other figure? Using adjusted figures creates a distracting debate, using the reported figures (and accepting that these are ESTIMATIONS) negates the debate.
If the line is really good, it might indeed deliver something higher than that projected using the reported attenuation, in which case the person advised will be delighted. If the higher speed projected by a wet-finger adjustment of the attenuation is not met, they will be disgruntled and feel short changed... leading to an unresolvable "I am not getting my fair share spat".
My preference is to set reasonable expectations and see people delighted when they are met and over joyed when they are exceeded, rather than set expectations which are more likely to be unfilled leading to dissatisfaction. Which camp will you settle in?
25-03-2015 3:50 PM
Quote from: Chris I'm here!
I'll go uncap the upstream for you.
Thanks for doing this. I haven't noticed any change on my connection - same IP address etc. Do I need to Disconnect, then Reboot the router?
Simon
25-03-2015 3:53 PM
25-03-2015 3:55 PM
Thanks,
Simon
25-03-2015 6:33 PM
Quote from: Townman Very few lines, even the best, will perform at their theoretical level. For setting reasonable expectations in people's minds, using the reported attenuation (in speed calculators) produces a figure which might be reasonably attained without entering into the debate about how much different ADSL(1) and ADSL2+ will report the attenuation to be on the same line. Is it 1.5dB, 2.5dB, 3dB or some other figure? Using adjusted figures creates a distracting debate, using the reported figures (and accepting that these are ESTIMATIONS) negates the debate.
So you are going to keep putting the wrong figure into the estimator then. There isn't really anything to debate here.
Quote from: Townman If the line is really good, it might indeed deliver something higher than that projected using the reported attenuation, in which case the person advised will be delighted. If the higher speed projected by a wet-finger adjustment of the attenuation is not met, they will be disgruntled and feel short changed... leading to an unresolvable "I am not getting my fair share spat".
Did you write this yourself or did another one help you?
Quote from: Townman My preference is to set reasonable expectations and see people delighted when they are met and over joyed when they are exceeded, rather than set expectations which are more likely to be unfilled leading to dissatisfaction. Which camp will you settle in?
I thought the answer to your final question should have been obvious if you look at the value I subtracted from the attenuation.
25-03-2015 7:07 PM
Quote from: ejs So you are going to keep putting the wrong figure into the estimator then. There isn't really anything to debate here
If 2dB and exactly 2dB will always be the difference between ADSL(1) and ADSL2+ on every line I agree the figure will always be wrong and there is nothing to debate. Whilst it might be about that figure, using the reported figure is near enough for setting reasonable expectations.
Quote from: ejs Did you write this yourself or did another one help you?
Such bickering helps no one - please stop it.
For the record, I am capable of writing my own observations thank you.
25-03-2015 7:57 PM
Quote from: Townman For the record, I am capable of writing my own observations thank you.
Thanks for not actually answering my question.
I don't suppose anyone is interested in finding out if this line would work better on ADSL2, since no-one can know for sure if it will or not in advance of trying it. I guess it's just tough luck then that some exchange equipment doesn't do that automatically. So this line is only doing slightly better than your presumably slightly longer line does on ADSL2. Although this line has interleaving off, which may explain the difference.
26-03-2015 10:32 AM
Mode: ADSL_2plus
Traffic Type: ATM
Status: Up
Link Power State: L0
Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (1 dB): 4.2 5.4
Attenuation (1 dB): 49.5 26.9
Output Power (1 dBm): 18.2 11.9
Attainable Rate (Kbps): 5732 1032
Path 0 Path 1
Downstream Upstream Downstream Upstream
Rate (Kbps): 5431 800 0 0
MSGc (# of bytes in overhead channel message): 59 14 0 0
B (# of bytes in Mux Data Frame): 169 100 0 0
M (# of Mux Data Frames in FEC Data Frame): 1 1 0 0
T (Mux Data Frames over sync bytes): 1 1 0 0
R (# of check bytes in FEC Data Frame): 0 0 0 0
S (ratio of FEC over PMD Data Frame length): 0.9956 4.0000 0.0 0.0
L (# of bits in PMD Data Frame): 1366 202 0 0
D (interleaver depth): 1 1 0 0
Delay (msec): 0 1 0.0 0.0
INP (DMT symbol): 0.00 0.00 0.0 0.0
Super Frames: 0 0 0 0
Super Frame Errors: 69343 318 0 0
RS Words: 0 2490294 0 0
RS Correctable Errors: 0 0 0 0
RS Uncorrectable Errors: 0 0 0 0
HEC Errors: 127950 201 0 0
OCD Errors: 22 0 0 0
LCD Errors: 22 0 0 0
Total Cells: 416606373 61352907 0 0
Data Cells: 8405193 732874 0 0
Bit Errors: 0 147 0 0
Total ES: 42003 272
Total SES: 65 3
Total UAS: 368 78
Looks like the US has improved just as you said.
Thank you to all who have got involved with improving my broadband. I'm really pleased with the result.
Best regards,
Simon
27-03-2015 6:37 AM
- « Previous
- 1
- 2
- Next »
