SNR reset please
- SNR reset please
- « Previous
- 1
- 2
- Next »
Re: SNR reset please
10-04-2013 11:25 AM
Quote from: _Adam_Walker_
In this case we need to raise an order to change the stability setting for your line, add interleaving and make sure no banding is applied (as per what you've experienced).
That will complete tomorrow, after that we'll submit an SNR reset. Following that the disconnections shouldn't affect DLM at all.
this is why adam did this the other day , so disconnections either by turning off or by logging in router n clicking disconnect wont affect DLM in the future (hopefully)
10-04-2013 11:34 AM
Quote we need to raise an order to change the stability setting for your line, add interleaving and make sure no banding is applied
which YOU then refused, and Adam said -
Quote OK I can leave interleaving off. But please bear in mind an SNR reset alone rarely fixes any issues it really depends on certain aspects of the line as to how DLM will react.
You have already found out how the DLM will react without interleaving - it drops your speed by a bigger than normal amount !
10-04-2013 11:39 AM
Quote from: purleigh And what part of Adam's statement didn't you understand ?
if you read it again , i didnt refuse, i said i wished to keep interleaving off, the rest i agreed too
10-04-2013 11:43 AM
Quote from: _Adam_Walker_ Not just yet, we need the order I placed yesterday to complete fist, no point submitting one until it has. I'll check the order again tomorrow for you and will reply back when the reset has been done.
UPDATE:
I've just checked and the order has completed so I've submitted the SNR reset now.
heres the update he suggested which was completed today, the only thing i didnt want doing was to turn interleaving back on, so i dont know which part you missed about me refusing the whole stability order
10-04-2013 11:45 AM
By preventing banding (not seen that done before !) that means after a DLM speed drop has occurred your line will probably recover after a week or so - rather than getting permanently stuck on a reduced banded rate in an attempt to maintain stability.
10-04-2013 1:22 PM
since chris mentioned about going into router and disconnecting that way, i had no probs at all,it kept constant speeds, so i guess it works in a way, it was only till sis turned off router it went back to low speed, but she knows now, so hopefully just using the router trick things will stay the same without DLM affecting the speed. time will tell..
still getting around 3mb at mo, but its too early still, will try more tests later when the reset kicks in
10-04-2013 3:07 PM
I really must advise NOT switching the router off, even when you're not using it. The electricity saving over the year will be measured in pence, not pounds.
10-04-2013 3:25 PM
will soon see when my reset kicks in later, when i do a test, n see after a few days, just doing the router log in/disconnect, as i hadnt a prob since i tried doing that
11-04-2013 9:47 AM
UPDATE:
hi adam are you sure the SNR was submitted as there as been no change since yesterday morning, i run a few tests yesterday evening
http://www.speedtest.net/result/2636701725.png
http://www.speedtest.net/result/2636931223.png
http://www.speedtest.net/result/2637023736.png
and one again this morning (below) as you can see nothing as changed, i should be seeing 15-17mb, not 3mb
http://www.speedtest.net/result/2638030154.png
11-04-2013 2:07 PM
11-04-2013 2:17 PM
Bad news - it was just a matter of updating the profile on our side I'm afraid. Good news - that's now done, the SNR reset has completed and removed the banding, and you should shortly be enjoying speeds of around 17Mb - hope that's all good now?
- « Previous
- 1
- 2
- Next »
