SNR reset please <cry>
- SNR reset please <cry>
- « Previous
- Next »
Re: SNR reset please <cry>
28-11-2015 4:03 PM
Estimated line speed:
Current line speed:
15.7 Mb
will double check the ini file..
Current line speed:
15.7 Mb
No problem can be solved from the same level of consciousness that created it.
Albert Einstein
Albert Einstein
Message 31 of 39
(611 Views)
28-11-2015 4:12 PM
You should be OK on Current Line Speed then - luckily
Message 32 of 39
(611 Views)
28-11-2015 4:14 PM
Don't hold your breath - a delta report may have come through and not been acted on yet
A quick check tomorrow morning will show whether you have been lucky
Message 33 of 39
(611 Views)
28-11-2015 4:16 PM
Fingers crossed oldjim.
AnotherOne: ok checked .ini bakup file and...
NO reference to (xdsl debug multimode config=t1.413issue2+g992.1_annex_a+g992.3_annex_a+g992.3_annex_l+g992.3_annex_m+g992.5_annex_a+g992.5_annex_m)
Albert Einstein
Albert Einstein
Message 34 of 39
(611 Views)
28-11-2015 4:19 PM
The "xdsl debug multimode ..." is not present in the saved configuration file by default. If it's not present, then the default configuration values will be used. There's "config adslmultimode=adsl2plus" under the xdsl.ini section, but that one doesn't actually affect anything if you change it to adsl2.
Message 35 of 39
(611 Views)
28-11-2015 4:25 PM
Jim, you could be right, but I'm gambling on the fact that the present CLS is exactly right for the latest sync speed, so fingers crossed as Rob says.
Rob, ejs may well have hit the nail on the head. I configured mine so long ago now, I've forgotten what I've tinkered with (as far as some things go) and what was there originally by default
Searching the file for things like adsl and g922. (with the dot on the end) might find all the relevant bits but the g922. may not come up with anything if it's all default settings
Message 36 of 39
(611 Views)
28-11-2015 4:39 PM
well the closest adsl hit on the .ini file was this:
config adslmultimode=adsl2plus detect-lop=enabled syslog=disabled
there are no g922. entries at all.
It seems these are default values set by P/Net
Albert Einstein
Albert Einstein
Message 37 of 39
(611 Views)
28-11-2015 4:56 PM
The default values are in the Firmware, and Plusnet won't have changed those. You can do so if you wish. But unless you know what you are doing, not recommended, nor do I see a need for your connection
Message 38 of 39
(611 Views)
28-11-2015 5:05 PM
sorry wrong thread
Message 39 of 39
(611 Views)
- « Previous
- Next »
