SNR problem
barny
SNR problem
I have an adsl 1 connection on a 21st cent exchange. I have recently installed a Billion Bipac 7800dxl to improve the line drop outs
The current system uptime is 69 days and 61 days on the present gateway 06 I suspect that
the target snr is 15 db due to the previous line history.
Would it be possible to try ADSL2 or an snr reset to improve the sync rate and subsequent download speed. Thank you!
Fixes: 33
Re: SNR problem
Hi barny,
After checking your account and running a quick line test it looks like an SNR reset would be a lot more helpful to you.
I've submitted that now so hopefully you should notice some improvement within the next 24 hours.
 Adam Walker
barny
Re: SNR problem
Thank you Adam have a good day.
barny
Re: SNR problem
Please can you correct my line profile to  2.74 to agree with the bt  profile thank you !
Plusnet Staff
Plusnet Staff
Re: SNR problem
As the profile doesn't appear to be stuck, it should happen automatically for you.
Tony
 Tony
 Plusnet Support
