SNR margin
iruhaku
SNR margin
Hi, just wondering if i can have my SNR set to 3 my DSL is stable uptime before i had to reset (puting xmas tree up) was almost 7 days and I'm on fast path but for some reason I'm not being put on the 3db profile.
router helpdesk stats
3 - Firmware version: 7.275.2_F2704N_Plusnet
4 - Board version: F@ST2704N
5 - Mode ADSL
6 - Uptime: 0 days 20:15:03
7 - Data rate: 1279/15437
8 - Maximum data rate: 1296/16252
9 - Noise margin: 6.4/7.1
10 - Line attenuation: 16.4/29.5
12 - Data sent/received: 468.3M/325.0M
20 - Broadband username: ********
21 - Wi-Fi network/SSID: ***
22 - Wi-Fi connections: Enable(802.11 b/g/n(up to 144 Mb/s))20 MHz WPS disabled
23 - Wi-Fi security: WPA2
24 - Wi-Fi channel: 6
25 - Firewall: Default
26 - MAC Address: ***********
27 - Software variant Version 1.0
28 - Boot loader: 7.275.2
Advanced stats
Mode: ADSL_2plus
Traffic Type: ATM
Status: Up
Link Power State: L0
Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (1 dB): 7.1 6.5
Attenuation (1 dB): 29.5 16.4
Output Power (1 dBm): 0.0 12.6
Attainable Rate (Kbps): 16180 1296
Path 0 Path 1
Downstream Upstream Downstream Upstream
Rate (Kbps): 15437 1279 0 0
MSGc (# of bytes in overhead channel message): 55 66 0 0
B (# of bytes in Mux Data Frame): 254 39 0 0
M (# of Mux Data Frames in FEC Data Frame): 1 1 0 0
T (Mux Data Frames over sync bytes): 2 1 0 0
R (# of check bytes in FEC Data Frame): 0 0 0 0
S (ratio of FEC over PMD Data Frame length): 0.5275 0.9756 0.0 0.0
L (# of bits in PMD Data Frame): 3867 328 0 0
D (interleaver depth): 1 1 0 0
Delay (msec): 0 0 0.0 0.0
INP (DMT symbol): 0.00 0.00 0.0 0.0
Super Frames: 0 0 0 0
Super Frame Errors: 1169 74 0 0
RS Words: 0 2287172 0 0
RS Correctable Errors: 0 0 0 0
RS Uncorrectable Errors: 0 0 0 0
HEC Errors: 5295 64 0 0
OCD Errors: 75 0 0 0
LCD Errors: 75 0 0 0
Total Cells: 2649175634 219239394 0 0
Data Cells: 189457733 13267659 0 0
Bit Errors: 0 6147 0 0
Total ES: 996 42
Total SES: 1 0
Total UAS: 53 53
1 REPLY
Fixes: 78
Re: SNR margin
The connection looks nice and steady so I don't see why we can't give that a go.
I've just submitted that for you.
The usual "this can take up to 24 hours but you might see a difference in a few" applies Smiley
 Adam Walker
