SNR margin dropping to 3dB after 4 to 5 days up time...
- SNR margin dropping to 3dB after 4 to 5 days up ti...
- « Previous
- 1
- 2
- Next »
Re: SNR margin dropping to 3dB after 4 to 5 days up time...
18-12-2010 4:29 PM
Just by way of an update; I had a brainwave this morning (must be the cold weather...) and removed a few things from around the master socket. I then did a re-sync and am now syncing at 3424Kb/s (maximum bandwith of 3520Kb/s), up from around 2912Kb/s pre-fiddle. SN Margin has been hovering around 6dB since too. Not a bad improvement for 2 minutes work.
Interestingly, when I did the re-sync, the line reconnected with an SN Margin of 6.5dB...
I'll need to wait a couple of days for my IP Profile to reset but, will run a speedtest then and publish the results.
Paul
Paul
Message 16 of 18
(323 Views)
04-01-2011 4:27 PM
OK, have been monitoring the dropping SN Margin over the Christmas period and it's still occuring, despite being connected directly to the test socket. It's quite an annoyance now as I need to re-sync the router every 5 days or so to get the SN Margin back up to 6dB or so as the connection quality, in terms of page loading etc, drops right off when the SN Margin hits 3dB. This is clearly set with obstacles as I need to re-sync at the right time to avoid the dreaded IP profile change. I'm also not at home during optimum 'sync hours'.
Would one of you kind people at Plusnet please investigate the issue for me?
If you need anything, just shout.
Thanks in advance,
Paul
Thanks in advance,
Paul
Message 17 of 18
(323 Views)
04-01-2011 4:31 PM
Hmm, sounds promising. Always worth fiddling, you never know what you can find
Message 18 of 18
(323 Views)
- « Previous
- 1
- 2
- Next »
