SNR low to zero especially in evenings
- SNR low to zero especially in evenings
20-03-2012 9:13 PM
Could one of the Plus.net guys or gals take a look at my connection as the SNR seems to be very low in the evenings accompanied by very slow download speeds which are making Netflix, iPlayer, etc continuously buffer.
I have tried reconnections and router resets to no avail.
I saw Jojo make some tweaks on another post which seemed to sort the problem.
Many thanks,
Hugh
Many thanks,
Hugh
Message 1 of 9
(1,817 Views)
8 REPLIES 8
Re: SNR low to zero especially in evenings
20-03-2012 10:51 PM
I had a similar issue for months and months this time last year in the end a replacement of both d and e sides was made and a replacement card at exchange possibly also a lift and shift. not seen the snr off 0 since then.
out of interest what router are you using is it a belkin per chance?
podman
podman
Message 2 of 9
(709 Views)
21-03-2012 7:25 AM
Hi there podman,
No, I have a Netgear DG834G v3.
Of course, this morning the downstream SNR is back to 5db and connection is fine.
Any help with this would be appreciated.
Thanks,
Hugh
Thanks,
Hugh
Message 3 of 9
(709 Views)
21-03-2012 2:46 PM
Hmm. If the sync rate and SNR are actually changing then it'll be something near your premises or the exchange as there's nothing we can do that would change those stats. It could be some piece of electrical equipment in a nearby house perhaps, if it always happens at the same time it's well worth looking to see if anything gets turned on nearby that could be causing it - street lights or heating, things like that?
Message 4 of 9
(709 Views)
21-03-2012 2:59 PM
Nothing obvious, and it doesn't always happen. Just that if it dies it tends to be in the evenings.
Thanks,
Hugh
Thanks,
Hugh
Message 5 of 9
(709 Views)
22-03-2012 9:20 AM
I'd advise raising a fault with us @hughconway https://portal.plus.net/apps/kbdfaults when doing so you should have an opportunity to enter some notes about the issues you're having in the evenings.
Message 6 of 9
(709 Views)
23-03-2012 8:50 AM
Quote from: hughconway I saw Jojo make some tweaks on another post which seemed to sort the problem.
I've had a go with yours but it will probably be Monday before it takes effect
Message 7 of 9
(709 Views)
23-03-2012 6:53 PM
Thanks Jojo
Message 8 of 9
(709 Views)
26-03-2012 10:20 AM
Let me know how it goes tonight
Message 9 of 9
(709 Views)
