SNR has suddenly increased and speed dropped
FIXED- Subscribe to RSS Feed
- Re: SNR has suddenly increased and speed dropped
- « Previous
- Next »
18-08-2016 12:34 PM
Post a selection of dusk/early evening and a late evening graphs anyway, as it will tell us a fair bit about your line. It might lead to some other check that could be done.
You don't need to resync the modem/router. If DLM decides it is going to lower the Target SNRM, it will all happen automatically. How long that may take depends, but if your line is stable (and clean enough) for a few more days, a manual reset could probably be requested.
18-08-2016 12:36 PM
Will do.
Thank you again.
Rob.
22-08-2016 7:01 AM
It's been a week now with no disconnects. I have monitored the SNR 24hours a day and there has been no real incidents even at dusk and early evening. There has been 3 "blips" has shown on the attached graphs.
Are they significant?
My download speed is still only 75% of what it was before the problem started but is consistent.
Would a SNR reset help get the speed back?
Regards, Rob.
22-08-2016 3:27 PM
That looks pretty good actually. There appears to be virtually an insignificant change between daylight and night, and the blips are not significant - less than about +/- ½dB eitehr due to a bit of cross-talk or minor interference from some device being switch off/on.
I would think an SNR Reset would be a good idea. Perhaps @MatthewWheeler could oblige?
22-08-2016 4:07 PM
Thanks Anotherone, your help has been really appreciated.
22-08-2016 7:35 PM
22-08-2016 8:15 PM - edited 23-08-2016 6:33 AM
Thank you Mathew. The SNR is now at 6.2 and the BT profile has now increased as well.
Thank you again,
Rob.
- « Previous
- Next »
