SNR fluctuating
- Re: SNR fluctuating
SNR fluctuating
01-05-2010 11:15 AM
Is this common folks? Downstream SNR was at 8.9db last night, it's now at a staggering 18.90dB!
Message 1 of 4
(677 Views)
3 REPLIES 3
Re: SNR fluctuating
02-05-2010 10:39 AM
No it's not....unless you've experienced line instability (re syncs) during the night that has caused the exchange DLM to raise your SNRM to try and stabilise it.
Message 2 of 4
(288 Views)
Re: SNR fluctuating
02-05-2010 12:26 PM
Or, you synced during a period of lots of noise, and the noise has subsequently disappeared, without a resync.
B.
B.
Message 3 of 4
(288 Views)
Re: SNR fluctuating
02-05-2010 12:46 PM
Thanks for the replies chaps - I'm well new to ADSL. It's sorted itself out now - back at my usual 15dB. Should stop checking my router stats every couple of hours I suppose. But it's all new to me and vaguely fascinating.
Message 4 of 4
(288 Views)
