SNR Target set request
- SNR Target set request
24-03-2014 2:50 PM
If any Plusnet support is watching these forums can I please have my SNR target setup at 3db. Could I also ask for a IP profile reset please ?
This follows after I replaced my old router with a Asus DSL N66U which is a brilliant piece of hardware but with a highly bugged ADSL driver and platform firmware. It should be pretty stable for now but for some reason the downstream attenuation is 25% higher than every other router/modem I have tried.
Re: SNR Target set request
24-03-2014 3:20 PM
24-03-2014 3:25 PM
24-03-2014 3:32 PM
24-03-2014 3:42 PM
Still the fact that N66U is reporting 40-41 attenuation on the downstream and other modems are showing in the 29-31 range is the most odd of things.
I've raised it with Asus. The router model is relatively new so I hope the problem is only temporary.
24-03-2014 7:25 PM
The SNR got defaulted back to 6 for some weird reason. Interleaving is still off.
25-03-2014 10:04 AM
Nobody from plusnet seen this yet ?
25-03-2014 10:06 AM
However if the target SNR has increased back to 6 then something is causing that to happen. Did you make any changes internally or know any reason that this might have happened?
25-03-2014 10:21 AM
No, there is something odd about this adsl driver firmware. I mean right now is showing a 4.5 db snrm on the downstream
Could you please request another reset. The only change I did was not related to the adsl connection. If something change I am probably about to find out another bug in the N66U platform.
25-03-2014 10:32 AM
Within this time the DLM will make changes depending on line stability.
