SNR Reset
- SNR Reset
Re: SNR Reset
05-03-2013 2:04 AM
I would suggest u to try different router as getting a MAC will not improve your line at all. It all down to your equipment really.
My line attenunation was 32dB and managed to get sync rate of 17315k from SNR of 3dB.
ADSL Link Downstream Upstream
Connection Speed 17315 kbps 1279 kbps
Line Attenuation 32.0 db 17.0 db
Noise Margin 3.3 db 5.5 db
Re: SNR Reset
06-03-2013 7:39 PM
@ goldenADSL - Thanks for the input. The router I'm using is a new ASUS DSL-N55U which is supposed to be (with the new firmware) a reliable and stable router, although not necessarily with the highest speed. I would rather sacrifice a little speed for reliability. I have also tried the line with an old but extremely reliable US Robotics 9108A, and although it synched quite a bit higher, the wireless is a bit flakey (I used this for the last 6 years 24/7/365). I have also tried it with a Belkin N600DB which synced at a similar speed to the ASUS. I have another half dozen or so routers (Netgear DG834G, 2Wire 2700HGV, several home hubs and an old Linksys BEFDSR41W, just in case!) and don't see the point in trying them all, it would probably confuse the exchnage and serve me up an SNR increase, which does seem to be settling down. I'll wait the 72 hours before deciding whether to throw any more routers at it!
Thanks,
Greg
Re: SNR Reset
07-03-2013 12:58 AM
There's no way the Target SNRM could have got lowered to 3dB "by mistake", DLM doesn't do that sort of thing and put it straight up again.. It may have gone down that low as a result of an increase in noise - remember more noise, less margin. See how it goes anyway.
Re: SNR Reset
07-03-2013 1:28 AM
Re: SNR Reset
08-03-2013 11:24 AM
Re: SNR Reset
11-03-2013 10:32 PM
Re: SNR Reset
12-03-2013 10:05 AM
Re: SNR Reset
12-03-2013 10:22 AM
Summarise the problem area in which it falls and any appropriate update and reference the previous ticket by it's number.
Re: SNR Reset
16-03-2013 11:00 PM
The engineer installed a new vDSL faceplate and seemed to think this solved the problem - his machine returned no errors, although it did fail a pair test once, which it passed the second time it was run. Shortly after he left, my router lost sync again (now plugged straight into the new vDSL socket). It has not lost sync since, but is now throwing up errors and the SNR is starting to fall quite quickly. It does look as though it will drop sync soon, leading me to think there may be a problem with the exchange equipment. I will post this on my ticket too. I don't think the old socket was faulty, and the new one doesn't seem to have cleared up the errors I was getting before - hopefully this can be sorted soon as everytime I lose sync I lose speed, although it has gone up a bit in the new faceplate
Router stats as of right now:
Update Counter : 16221
Modulation : ADSL2+
Annex Mode : Annex A/L
Line State : up
Lan Tx : 1433306
Lan Rx : 774576
ADSL Tx : 555557
ADSL Rx : 900577
CRC Down : 0
CRC Up : 255
FEC Down : 0
FEC Up : 34494
HEC Down : 6200
HEC Up : 0
SNR Up : 4.9
SNR Down : 3.7
Line Attenuation Up : 17.4
Line Attenuation Down : 30.0
Data Rate Up : 1076
Data Rate Down : 15218
Re: SNR Reset
17-03-2013 3:33 PM
Quote from: austinsom ..........although it did fail a pair test once.........
In light of that I'm not sure why you think there may be an exchange fault. That and the other symptoms you are describing are typical of an intermittent line fault. When the engineer had that failure he should have put his JDSU away and got his Hawk tester out and started looking.
You will need to be a bit OCD listening to your phone line for crackling noises etc.
Even if there's nothing wrong with either faceplate, I'd stick with the vDSLplate as it is a quality filter.
Re: SNR Reset
21-03-2013 9:40 PM
@ Plusnet - I am VERY disappointed to find that both of my tickets regarding this fault have been closed, even though I replied to one of them stating that there was still a fault due to the line dropping and a large number of errors and unstable SNR margin. Am I really going to have to go through all of this again and try to explain this from the beginning. I am really angry as it does not appear that anyone actually bothered to look at the ticket before closing it. I am sure I will get the 'it was closed by the supplier' brush off, but really some one should have looked at it first. I would therefore request that both tickets are re-opened immediately so that this ongoing fault can be identified and fixed as it is absolutely ridiculous that after a month I am still having problems. I am still getting a constant hiss on the voice line (DECT 'phone) that seems to have gotten slightly worse as the errors on the broadband have increased, although this may be psychological.
So I am disappointed that my tickets have been closed, and I would ask one of the Plusnet staff to look into this for me before I open yet another fault as I really don' want to have to start back at the beginning. I still have time on my MAC and it is now looking quite likely it will be used.
Just for info, my router re-synced this morning at 6am, lost more sync speed and has the following stats as of right now:
Update Counter : 68777
Modulation : ADSL2+
Line State : up
Lan Tx : 12815953
Lan Rx : 7312906
ADSL Tx : 1656243
ADSL Rx : 2285932
CRC Down : 0
CRC Up : 4662
FEC Down : 0
FEC Up : 50741
HEC Down : 7397
HEC Up : 04
SNR Up : 5.3
SNR Down : 3.0
Line Attenuation Up : 17.5
Data Rate Up : 1067
Data Rate Down : 14009
and my TBB graph shows a couple of disconnects by the looks of it...
I will also be raising this as a complaint - enough is enough
Re: SNR Reset
21-03-2013 10:46 PM
Update Counter : 70108
Modulation : ADSL2+
Line State : up
Lan Tx : 13007255
Lan Rx : 7418690
ADSL Tx : 1756370
ADSL Rx : 2457269
CRC Down : 0
CRC Up : 5652
FEC Down : 0
FEC Up : 62035
HEC Down : 8617
HEC Up : 04
SNR Up : 5.3
SNR Down : 3.3
Data Rate Up : 1067
I'm willing to put money on the connection dropping overnight/early tomorrow AM as the stats are looking very poor. I want a response to this and some action tomorrow. PM/'phone me to make an engineer appointment - you have the details...
Re: SNR Reset
21-03-2013 11:54 PM
Edit: You don't have to explain everything again if it was in a previous ticket - look through you closed tickets to find the relevant one and reference it in the new ticket with whatever additional information is relevant. Unfortunately tickets are automatically closed by the system if there is no activity on the ticket for more than 14 days.
Edit2: In any event, BTw will have closed off the previous fault at their end, not that it matters because Plusnet just raise another.
Intermittent faults are difficult to find at the best of times and it's not Plusnet's fault that Openreach haven't managed to find the cause yet.
Re: SNR Reset
22-03-2013 7:35 AM
I will open another ticket - but I still want a member of PN staff to look at this ticket and explain what on Earth is going on and why this has taken 6 weeks, 2 tickets and no resolution.
I appreciate that iit is BTw who closed the fault, but I do not pay my money to BT. I have a contract with PN, so I expect them to fix/resolve any faults before closing them. PN then have a contract with BTw, so if a fault is closed before it is fixed they should be all over BTw like a cheap suit - I shouldn't have to keep checking to make sure something remains open when I am adding to it.
I now think it is a exchange/ exchnage to premises issue as there is nothing left to change on my side of the wall!
Re: SNR Reset
22-03-2013 1:44 PM
Post the new ticket number when you've got it and hopefully a DCT member will pick it up.
