SNR Reset
apjashley1
SNR Reset
Please can I have an SNR reset?
Changing down router firmware seems to have cleared a fault, and my line has been very stable (except for some manual resets this morning)
20 REPLIES 20
chrispurvey
Re: SNR Reset
That's been requested for you, give it around 4 hours Smiley
apjashley1
Re: SNR Reset
Thanks Chris but nothing so far...?
chrispurvey
Re: SNR Reset
I've placed the order again as the previous one failed, it looks like this one has gone through.
Keep me updated.
apjashley1
Re: SNR Reset
Please can someone give this another go for me today - the last two reset requests failed Sad
orbrey
Re: SNR Reset
Hi, looks like one took effect yesterday for you? From your line stats on the BT side we get our records from everything has definitely reset.
apjashley1
Re: SNR Reset
That's strange - I didn't get a resync (other than my manual resets yesterday for telnet tinkering) and my sync speeds and SNR figures haven't improved
adamwalker
Fixes: 221
Re: SNR Reset
Just wondering if this is still an issue for you? I can see a few disconnections from the 31st I'm assuming that may have been you rebooting the router?
Adam
 Adam Walker
apjashley1
Re: SNR Reset
Hi Adam,
Yes high SNR is still an issue unfortunately.
Everything on the 31st was me trying to block my freeloading neighbour from the network!
adamwalker
Fixes: 221
Re: SNR Reset
I've just submitted another SNR reset, hopefully this one will work and push the noise margin back down for you.
 Adam Walker
apjashley1
Re: SNR Reset
Nothing so far Sad
adamwalker
Fixes: 221
Re: SNR Reset
Sorry to hear that, I can't see any signs of an issue here so what speeds are you seeing at the moment?
 Adam Walker
apjashley1
Re: SNR Reset
11Meg, which isn't awful but my line can do better!
I just can't understand why your SNR resets don't cause me to re-sync and have no effect on SNR reported by the router at my end...
DSL Connection
Link Information
Uptime: 2 days, 19:26:40
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1.032 / 11.066
Data Transferred (Sent/Received) [GB/GB]: 1,99 / 1,99
Output Power (Up/Down) [dBm]: 12,1 / 20,9
Line Attenuation (Up/Down) [dB]: 11,3 / 24,0
SN Margin (Up/Down) [dB]: 4,9 / 11,9
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Link (Remote): -
Error Seconds (Local/Remote): 4.255 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 3.928 / 5.547
HEC Errors (Up/Down): 2.650 / 27.954
apjashley1
Re: SNR Reset
Anyone, please?
The member centre says my speed estimate is 17 meg but I'm only getting 11
jelv
Fixes: 10
Re: SNR Reset
Could you repost the stats so we can see what's happened in the last 24 hours please.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
